Export as FBX
On 22/02/2010 at 03:43, xxxxxxxx wrote:
Cinema 4D Version:   11& 11.5
Platform:   Windows  ;
Hi everybody,
This is an easy question, mostly a yes/no question though if anybody bothers to elaborate well... I am all ears 🙂
Saving your scene as .C4D with COFFEE is kinda trivial but.. can I save it as FBX with a COFFEE script (without using File/Export )?
If yes...Any hints, bits or pieces of code that I can look up?
Thanx a lot.
Giant-cfr
On 23/02/2010 at 02:11, xxxxxxxx wrote:
No, not possible with COFFEE.
cheers,
Matthias
On 24/03/2010 at 07:21, xxxxxxxx wrote:
How to do this in C++?
For most formats that would be SaveDocument(), however, FBX and a few others are not in the list of defines... is that for a reason?
Kabe
On 24/03/2010 at 08:36, xxxxxxxx wrote:
It should work by passing the exporter's plugin ID. The missing exporter/importer IDs have been probably just forgotten to add to the list.
cheers,
Matthias
On 24/03/2010 at 14:29, xxxxxxxx wrote:
I've used this with some success:
   SaveDocument(doc, filename, FALSE, 1017081);
Caveat: You might run into problems saving UVs. Sometimes the UVs are not written to the FBX file if a material is assigned but there's nothing in the color channel. A workaround is to assign a dummy texture to the material's color channel.
If anyone knows a better fix for that, I'd love to know it
On 24/03/2010 at 14:40, xxxxxxxx wrote:
Matthias, could you search for the missing exporter plugin IDs, please?
Besides FBX the most obvious omissions are STL and Collada...
Thanks a million
Klaus
On 25/03/2010 at 02:17, xxxxxxxx wrote:
FBX 2010.2 - 1023841
FBX 6 - 1017081
COLLADA - 1022316
Here the code to get all exporter IDs.
Bool MenuTest::Execute(BaseDocument *doc)
  AutoAlloc<AtomArray> arr;
  if (!arr) return FALSE;
  if (!FilterPluginList(arr, C4DPL_SCENESAVER, FALSE)) return FALSE;
  LONG cnt = arr->GetCount();
  for (LONG i=0; i<cnt; i++)
      BasePlugin *plugin = NULL;
      plugin =  (BasePlugin* )arr->GetIndex(i);
      if (plugin)
          GePrint(plugin->GetName()+" "+LongToString(plugin->GetID()));
  return TRUE;
cheers,
Matthias
On 25/03/2010 at 02:30, xxxxxxxx wrote:
Danke!
Kabe ツ
