On 20/02/2010 at 10:07, xxxxxxxx wrote:
--------- I am trying to create a MaterialData plugin. I have included a Shaderlink in to a channel. I would like that when the user selects and option afrom that shader link, that choice becomes the surface of the material. FOr example, if they choose and image, I would like that image to become the surface of the material. How do I go about doing this? I assume this is done in CalcSurface(). Is there an example in the SDK that shows how to accomplish this?
Thanks,
~Shawn
On 24/02/2010 at 02:24, xxxxxxxx wrote:
Yes, you have to overwrite CalcSurface(). To sample the shader link use PluginShader::Sample(). You have to generate the texure projection manually. See the example code of TexData in the SDK docu.
here a simple example, it samples a shader using UV projection (make sure the texture tag is set to UVW projection) :
///////////////////////////////////////////////////////////// // CINEMA 4D SDK // ///////////////////////////////////////////////////////////// // (c) 1989-2004 MAXON Computer GmbH, all rights reserved // ///////////////////////////////////////////////////////////// // volumetric shader example that accesses particles and displays its own preview // absolutely not optimized for speed #include "c4d.h" #include "c4d_symbols.h" #include "mparticlevolume.h" class ParticleVolume : public MaterialData { public: virtual Bool Init(GeListNode *node); virtual LONG GetRenderInfo(PluginMaterial *mat) { return 0; } virtual LONG InitRender(PluginMaterial *mat, InitRenderStruct *irs); virtual void FreeRender(PluginMaterial *mat); virtual void CalcSurface(PluginMaterial *mat, VolumeData *vd); static NodeData *Alloc(void) { return gNew ParticleVolume; } private: PluginShader *shader; }; Bool ParticleVolume::Init(GeListNode *node) { shader=NULL; BaseContainer *data = ((PluginShader* )node)->GetDataInstance(); data->SetLink(MY_SHADER, NULL); return TRUE; } LONG ParticleVolume::InitRender(PluginMaterial *mat, InitRenderStruct *irs) { BaseContainer *data = mat->GetDataInstance(); // cd.t = irs->time.Get(); shader = (PluginShader* )data->GetLink(MY_SHADER,irs->doc,Xbase); if (shader) return shader->InitRender(irs); return LOAD_OK; } void ParticleVolume::FreeRender(PluginMaterial *mat) { if (shader) shader->FreeRender(); shader=NULL; } void ParticleVolume::CalcSurface(PluginMaterial *mat, VolumeData *vd) { vd->trans = 0.0; ChannelData cd(vd); Vector uv; cd.p = vd->GetPointUVW(vd->tex, vd->lhit, vd->p); if (shader) { vd->col = shader->Sample(&cd); } } // be sure to use a unique ID obtained from www.plugincafe.com #define ID_PARTICLEVOLUME 1001163 Bool RegisterParticleVolume(void) { // decide by name if the plugin shall be registered - just for user convenience String name=GeLoadString(IDS_PARTICLEVOLUME); if (!name.Content()) return TRUE; name = GeGetDefaultFilename(DEFAULTFILENAME_SHADER_VOLUME)+name; // place in default Shader section return RegisterMaterialPlugin(ID_PARTICLEVOLUME,name,0,ParticleVolume::Alloc,"MParticleVolume",0); }
