Demo Plugin Version.
On 11/02/2010 at 16:05, xxxxxxxx wrote:
Cinema 4D Version:   11.5
Platform:   Windows  ;
I am trying to set up my plugin so that it works 100% in the DEMO version of C4D without having to be registered.
Here's what I am trying.
//SERIAL CODE/////////////////////////////////
class PlanetXSerial : public SNHookClass
  private:
  const String title;
  String name;
  Bool sn_ok;
public:
  PlanetXSerial() : title("Planet X Generator") {}
  virtual LONG SNCheck(const String &c4dsn,const String &sn,LONG regdate,LONG curdate)
      LONG err=0;
      SerialInfo si;
      GeGetSerialInfo(SERIAL_CINEMA4D, &si);
      LONG mySN = si.nr.SubStr(6,5).StringToLong(&err);
      LONG myAlgorithm = **REMOVED**
      String mySerial = LongToString(myAlgorithm);
      if (GeGetVersionType() == VERSION_DEMO)
          GePrint("DEMO");
          sn_ok = TRUE;
          return SN_OKAY;
      else
          if (sn == mySerial)
              GePrint("LICENSED");
              sn_ok = TRUE;
              return SN_OKAY;
          else
              GePrint("WRONG SERIAL");
              sn_ok = FALSE;
              return SN_WRONGNUMBER;
  virtual const String& GetTitle()
      return title;
  Bool IsSerialOK() const { return sn_ok; }
PlanetXSerial *snhook = NULL;
Bool RegisterPlanetXSerial()
  snhook = gNew PlanetXSerial;
  return snhook->Register(ID_PLANET_OBJECT_SERIAL, SNFLAG_OWN);
  return FALSE;
void FreePlanetXSerial()
  if (snhook)
      gDelete(snhook);
Bool IsSerialOKHook()
  if (snhook)
      return snhook->IsSerialOK();
  return FALSE;
The problem is with what I have, is not allowing the plugin to be loaded in the DEMO version of C4D.   Does anyone see a problem with this setup?
Thanks,
~Shawn
On 11/02/2010 at 23:46, xxxxxxxx wrote:
Depending on which Cinema version you are using you have to check for VERSION_SAVABLEDEMO or VERSION_SAVABLEDEMO_ACTIVE instead of VERSION_DEMO.
cheers,
Matthias
On 12/02/2010 at 06:40, xxxxxxxx wrote:
And what is the exact dependency? From R11 on checking for these two instead of VERSON_DEMO? Is VERSON_DEMO completely gone now or should one still check for it? Thanks
On 12/02/2010 at 08:02, xxxxxxxx wrote:
I changed the code to check for VERSION_SAVABLEDEMO || VERSION_SAVABLEDEMO_ACTIVE
and it still does not show up in the demo version.
Any thoughts?
~Shawn
hmm, it seems to me that the demo does not call SNCheck at all. Is that right? I installed the latest demo and it doesn´t seem to be called. Also a print to the console does not appear accordingly. If I´m right, what´s the right place to check for the demo? If I´m mistaken, it is strange as I am returning SN_OKAY if it´s the demo version but my plugin doesn´t appear in the menu (custom menu entry).
thanks in advance
On 12/02/2010 at 08:53, xxxxxxxx wrote:
I tried putting...
if (GeGetVersionType() == VERSION_SAVABLEDEMO || VERSION_SAVABLEDEMO_ACTIVE)
 if( !RegisterIsSerialOKHook()) return FALSE;
in the main.cpp   and still had no luck.  🙂
although if the demo doesn't call SNCheck at all then I suppose that wouldn't work then ...  LOL
~Shawn
in any case you should use GeGetVersionType() & VERSION_SAVABLEDEMO.  Not == because the returned LONG value is considered a bit field in this case not directly a digit (though it of course will still work but you are on the safe side this way).
On 12/02/2010 at 09:00, xxxxxxxx wrote:
oh.. right .. thanks Katachi.
On 13/02/2010 at 06:02, xxxxxxxx wrote:
Okay so I tried this in the main.cpp..
Bool PluginStart(void)
  // example of installing a crashhandler
  old_handler = C4DOS.CrashHandler; // backup the original handler (must be called!)
  C4DOS.CrashHandler = SDKCrashHandler; // insert the own handler
  //GePrint("PLANET X GENERATOR IS AVAILABLE FOR DEMO USE ONLY!");
      if (GeGetVersionType() &VERSION_SAVABLEDEMO_ACTIVE || VERSION_SAVABLEDEMO || VERSION_DEMO)
      else
          GePrint("NOT THE DEMO");
          GePrint("THE VERSION TYPE IS " + LongToString(GeGetVersionType()));
          if (!IsSerialOKHook()) return FALSE; //don't load plugins if key is wrong
  // Planet Object
  if (!RegisterPlanet()) return FALSE;
  // Sun Object
  if (!RegisterSun()) return FALSE;
  // Space Object
  if (!RegisterSpace()) return FALSE;
  //SERIAL NUMBER
  if (!RegisterPlanetXSerial()) return FALSE;
  return RegisterPlanet() && RegisterSun() && RegisterSpace();
When I am in the demo mode I get the plugin enabled and I am able to use it and as expected, the console prints out....
However, when I am using my registered copy of the plugin, I am also able to use it and the console prints out...
Why do you think this is happening?
~Shawn
On 13/02/2010 at 07:01, xxxxxxxx wrote:
Well...  thanks to a heaping helping of kindness from Cactus Dan,  this problem has been solved.   Here's the final working code for the PluginStart();
      if(GeGetVersionType()&VERSION_SAVABLEDEMO_ACTIVE || GeGetVersionType()&VERSION_SAVABLEDEMO || GeGetVersionType()&VERSION_DEMO)
      else
  // Planet Object
  // Sun Object
  // Space Object
  //SERIAL NUMBER
On 13/02/2010 at 07:31, xxxxxxxx wrote:
The line looks strange to me:
GeGetVersionType() &VERSION;_SAVABLEDEMO_ACTIVE || VERSION_SAVABLEDEMO || VERSION_DEMO
Shouldn't it be:
GeGetVersionType() == VERSION_SAVABLEDEMO_ACTIVE || VERSION_SAVABLEDEMO || VERSION_DEMO
[EDIT]Oh no, wait. Forget about this. & is correct.[/EDIT]
Jack
On 13/02/2010 at 07:33, xxxxxxxx wrote:
Actually, that looks strange to me, too:
    // Planet Object
    // Sun Object
    // Space Object
    //SERIAL NUMBER
So, you first try to register the plugins. When this succeeds, you register them all again and return the result? Why don't you just return TRUE at the end of the function, since they're already registered?
Jack
On 13/02/2010 at 07:45, xxxxxxxx wrote:
so instead of
do...
return TRUE;
~Shawn
On 13/02/2010 at 09:53, xxxxxxxx wrote:
GeGetVersionType() returns a bit mask. So you have to check against your own bit mask.
Remember that || and & & are compare operators.
| and & are bit mask operators.
Following line of code checks if the result of GeGetversionType() has one of the specified bits set.
if (GeGetVersionType() & (VERSION_SAVABLEDEMO_ACTIVE | VERSION_SAVABLEDEMO | VERSION_DEMO))
  //do something
cheers,
Matthias
so instead of
do...
return TRUE;
Yes. You have already called all Register functions before, so if the function reaches this point, you can just return TRUE. If one of the Register functions does not work out (returns FALSE) the PluginStart function is cancelled anyway and FALSE is returned.
Jack
VERSION_DEMO is not used anymore since the R11 demo version.
cheers,
Matthias
The demo version doesn't support the SNHookClass because it has no Personalioze dialog anyway.
Check in C4DPL_INIT_SYS for the Cinema version (that's where you would register the SNHookClass too).
cheers,
Matthias
On 15/02/2010 at 04:18, xxxxxxxx wrote:
Thanks Matthias.
