get baked particle information
On 11/02/2010 at 13:44, xxxxxxxx wrote:
Cinema 4D Version:   r11
Platform:
hi,
another thing that i cant find, is there a way to read the information stored in the particles bake-tag?
would be cool if someone could provide some info on this
cheers,
ello
On 12/02/2010 at 01:41, xxxxxxxx wrote:
No, you only have access to the ParticleObject class.
cheers,
Matthias
On 12/02/2010 at 02:37, xxxxxxxx wrote:
ah, so is there any way to get the information about where a particle has been at frame(x)??
On 12/02/2010 at 02:57, xxxxxxxx wrote:
You have to animate the document to the specific frame and get the particle array with GetParticleR().
cheers,
Matthias
On 12/02/2010 at 03:14, xxxxxxxx wrote:
so there is a way to be for example at frame 10 and internally animate the document to frame 3 and get the values from there??
Are those the things to use ??
AnimateDocument(BaseThread* bt, Bool doexpressions, Bool doanim) How do i specify the frame number here?
AnimateObject(BaseList2D* op, const BaseTime& time, LONG flags)
thanks,
ello
On 12/02/2010 at 06:36, xxxxxxxx wrote:
With BaseDocument::SetTime() you set the dosument's time and then AnimateDocument() to actually animate the document to the set time.
What version are you compiling for? Because in R11.5 AnimateDocument() has been replaced by ExecutePasses().
cheers,
Matthias
thank you.. i'll try that. i hope it is what i am looking for :)
I am targeting r11 at the moment, but i am trying to keep a r11.5 version at the same state
cheers,
ello
