reading serial from text-dokument
On 07/02/2010 at 05:25, xxxxxxxx wrote:
Cinema 4D Version:   11.5
Platform:      Mac OSX  ;
Hello again,
I have a Problem to get my serilization run....I want to deliver the users a Serial which is inside a Text-document. I cant figure out how to read out that serial from my txt.-document.
This is my code so far....what I am doing wrong?
I hope you can help me.
Greetings, Holger
var key_file = plugin_path->GetClone();
    key_file->AddLast("serial.txt");
    var key_txt=new(BaseFile);
key_txt->Open(key_file, GE_READ);
var key_num = key_txt->ReadString(0,GE_XBIT);
var key = ievaluate(key_txt);
println (key);
On 09/02/2010 at 03:06, xxxxxxxx wrote:
this is how i do it
String GetFileContent(const Filename& fn)
     AutoAlloc<BaseFile> bfile;
     if (!bfile)
          //MessageDialog("Test: BaseFile");
          return "";
     if (!bfile->Open(fn, GE_READ, FILE_IGNOREOPEN, GE_INTEL))
          //MessageDialog("Test: bfile->Open");
          return "No Registration found!";
     String line = "";
     VLONG fileLength = bfile->GetLength();
     CHAR c[2];
     c[1] = 0;
     CHAR* pc = &c;[0];
     for (LONG i = 0L; i != fileLength; ++i)
          bfile->ReadChar(pc);
          // Line read from the file
          line += String(pc);
     bfile->Close();
     return line;
hope it helps
On 09/02/2010 at 03:15, xxxxxxxx wrote:
Taahnk you ello....I got it run.
