On 28/01/2010 at 08:42, xxxxxxxx wrote:
--------- I'm doing something wrong here, or misinterpreting how the SelectionChanger works. What I want to do is get the points corresponding to a selected polygon or polygons. The code snippet looks like this:
// obj is a valid pointer to a PolygonObject // I'm in polygon mode BaseSelect *selPolys, *convPoints;
selPolys = obj->GetPolygonS(); // get selected polygons AutoAlloc<SelectionChanger> sc; sc->InitFromSelection(selPolys, Mpolygons, obj); convPoints = sc->GetPointS(); // convert polygon selection to points
This compiles and runs but if the polygon object has one selected polygon, convPoints->GetCount() returns 1 - but I thought it would return 4, one for each point in the polygon. Also, the one point it contains is not actually in the selected polygon.
I'm sure I've misunderstood how this works - can anyone enlighten me?
Many thanks,
Steve
On 01/02/2010 at 03:52, xxxxxxxx wrote:
Sorry to bump this but does anyone have any thoughts on this? I still can't get it to work, but it would be nice to know if at least I've got the underlying concept right.
On 02/02/2010 at 02:51, xxxxxxxx wrote:
I am not sure what's going wrong. Your code looks ok. Here is my test code which gave me correct results.
Bool MenuTest::Execute(BaseDocument *doc) { BaseObject *op = doc->GetActiveObject(); if (!op || op->GetType() != Opolygon) return FALSE; BaseSelect *polysel = ToPoly(op)->GetPolygonS(); AutoAlloc<SelectionChanger> sc; if (!sc) return FALSE; if (sc->InitFromSelection(polysel, Mpolygons, ToPoly(op))) { BaseSelect *pointsel = sc->GetPointS(); LONG seg=0,a,b,i; while (pointsel->GetRange(seg++,&a,&b)) { for (i=a; i<=b; ++i) { // i is the selected point GePrint(LongToString(i)); } } } return TRUE; }
On 02/02/2010 at 09:23, xxxxxxxx wrote:
Thanks Matthias. I now know that what I was doing was correct, and I think I know where the problem is.
Where possible I start developing my plugins in R10.111, partly so I can support older versions of Cinema, but mostly because I use R11.5 for most of my work, so I can have R10 stripped down to loading nothing other than my developing plugins.
Basically, I think the selection changer doesn't work correctly in R10. It works as expected in R11 and R11.5, but in R10 the code you showed does the same as mine - returns one selected point. R11 upwards returns 4 points, as expected.
I had a quick look in the R10 and R10.5 SDKs but I couldn't see anything about this in the changes section. I guess for this plugin it'll have to be R11 upwards as a requirement.
Many thanks for your help with this.
