How to get plugin name - plugin id mapping?
On 28/01/2010 at 04:52, xxxxxxxx wrote:
Cinema 4D Version: 11.5
Platform: Mac OSX ;
Is there a list of plugin id - plugin name mappings somewhere?I need to find ID for fbx plugins. On windows I've managed to iterate through all plugins and do this:
// list all plugins BasePlugin\* p = GetFirstPlugin(); while (p) { GePrint("Plugin: "); GePrint(p->GetFilename().GetString()); GePrint(LongToString(p->GetID())); p = p->GetNext(); }
But on mac p->GetFilename().GetString() returns empty strings, so I can't get the mappings. Why would it return empty strings?
On 28/01/2010 at 05:57, xxxxxxxx wrote:
It does work on Mac. Unfortunatly the console output is delayed. For instance if you call it from a command plugin it's displayed after exiting the plugin.
cheers,
Matthias
On 28/01/2010 at 06:49, xxxxxxxx wrote:
I can see the console output - it outputs ids, but not the names.
When filtering plugins using FilterPluginList (for SCENESAVER) - I get some names )I found one fbx plugin).
On 28/01/2010 at 06:52, xxxxxxxx wrote:
Hm, it works fine here. I used the same code as you. Which OSX version are you using?
cheers,
Matthias
On 01/02/2010 at 00:36, xxxxxxxx wrote:
IIRC 10.5
