On 29/12/2009 at 14:25, xxxxxxxx wrote:
User Information: Cinema 4D Version: 11+ Platform: Language(s) : C++ ;
--------- I have two plugins I am trying to get to talk to each other. I have a command plugin that needs to draw to the editor when the user toggles a button. I am using a SceneHookData plugin to accomplish the actual drawing. So, I want to send a message to the SceneHook to tell it what state the toggle button is in to activate the drawing in the Draw function.
I can successfully pass the message from my Command Plugin to main.cpp, but my question is how to get this information into my SceneHookData plugin. How can I receive that message inside the SceneHookData?
Thanks!
On 30/12/2009 at 02:21, xxxxxxxx wrote:
With BaseDocument::FindSceneHook(PluginID) you can get your scene hook and change for instance a value in its BaseContainer according to toggle button. In the scene hooks draw function read out the container value. You can trigger a redraw from within the CommandData with DrawViews().
On 30/12/2009 at 09:13, xxxxxxxx wrote:
I would rather use a message data plugin and use SpecialEventAdd to send out a message to all plugins and accordingly catch the message and react (fcourse you should also be able to catch the message in a SHP). Just an idea.
On 30/12/2009 at 19:10, xxxxxxxx wrote:
Great. Thanks for the suggestions!
On 06/07/2010 at 01:15, xxxxxxxx wrote:
"With BaseDocument::FindSceneHook(PluginID) you can get your scene hook and change for instance a value in its BaseContainer"
could someone give a bit more info on this? maybe how it looks in code.
thanks alot
On 07/07/2010 at 03:27, xxxxxxxx wrote:
Here is a little example how to change a container value for a scene hook from within a CommandData plugin for example.
PluginSceneHook *sh = doc->FindSceneHook(ID_MYSCENEHOOK); if (sh) { BaseContainer *data = sh->GetDataInstance(); data->SetLong(MYSCENEHOOK_VALUE, 100); EventAdd(); }
On 08/07/2010 at 16:54, xxxxxxxx wrote:
