OS Error loading Plugin
    On 17/12/2009 at 07:33, xxxxxxxx wrote:
    Cinema 4D Version:   11.529
    Platform:   Windows  ;
    Language(s) :
    Hello All,
    On x64 my plugins (pathdeformer and vraybridge for now) fail to load on the 11.529 64bit.
    The error returned in console is:
    Error: OS loading plugin plugin.cdl64, GetLastError return 0.
    Does someone got same error ?
    thanks in advance
    renato
    On 17/12/2009 at 07:59, xxxxxxxx wrote:
    If you use a c4d beta built you should rather contact MAXON directly for this issue. In 11.528 it works fine here. No problems.
    On 17/12/2009 at 08:06, xxxxxxxx wrote:
    Hello Robert,
    so you got same error with 11.529?
    On 17/12/2009 at 08:08, xxxxxxxx wrote:
    ops.. Samir :)
    On 17/12/2009 at 09:34, xxxxxxxx wrote:
    Ok, with the 11.528 now it work :)
    thanks for the suggestion
    renato
    On 25/11/2011 at 01:08, xxxxxxxx wrote:
    Hello All,
    same problem when i switch back from vs2008 to the vs2005.
    Error: loading plugin vraybridge.cdl GetLastError return 0..
    I'm working on R12.048, Vs2005 and the projects was made from the c4dsdk.vcproj.
    someone have a suggestion?
    thanks in advance
    renato
    On 25/11/2011 at 03:11, xxxxxxxx wrote:
    Originally posted by xxxxxxxx
    Hello All,
    thanks in advance
    renato
    Well you have to check that on your side.
    The message happens, if the Windows LoadLibraryW() call - loading (and initializing) the vraybridge.cdl - returns NULL instead of a pointer to the dll.
    Best regards,
    Wilfried Behne
