On 05/12/2009 at 01:43, xxxxxxxx wrote:
User Information: Cinema 4D Version: 11.5 Platform: Windows ; Mac OSX ; Language(s) : C++ ;
--------- Hello All, i have 3 question about shortcuts. 1)i know is possible to add new shortcut in command manager with AddShortcut(bc). but where i have to write this? i have tryed to insetri in plugin message but each cinema start duplicate my entry? 2)can i know if user have a customized my shorcuts ? i wan't to damage his custom settings ? 3) i have some tool plugin with a lot of mouse input shortcuts, is possible to add this shotcuts in command manager to allow the user to change it ? thanks in advance Franz
On 09/12/2009 at 03:09, xxxxxxxx wrote:
no reply Franz
On 09/12/2009 at 04:00, xxxxxxxx wrote:
I have to check this.
At Cinema start you can check the shortcut list with GetShortcutCount() and GetShort().
Not possible through the Command Manager but you can offer it through your tool interface. This is how the Joint tool for instance is doing it.
Personally I wouldn't change the shortcut list but leave it to the user to customize the shortcuts.
