On 21/11/2009 at 02:31, xxxxxxxx wrote:
User Information: Cinema 4D Version: Platform: Language(s) : C++ ;
--------- Hi,
I need to get sth done but im not sure about tzhe best approach, as i dont have so much experience with splines actually.
Here's the problem: Imagine you have some arbitrary spline and you want everything beyond a certain X-value to be flat, just like you booled it with an rectangle, that came in from the side.
My first idea was to use the built-in GetPosition(t) and GetTangent(t) function which would give me a vector position and a tangent for that position on the spline, in regards to its length (t: 0->1.0).
The problem is though i dont have that 't' value. all i have is an x-value like, everything beyond x=20.0 should be flat.
What i need is all points on the spline, that have x=20.0 *and* the tangents of those points.
Any ideas how to do that ? Maybe the SplineHelp class can help there, but it looks like all important functions work on the length of the spline exclusively.
thanks, Daniel
On 25/11/2009 at 04:02, xxxxxxxx wrote:
Hi, i narrowed it down a little, by finding the indices of the SplineObject points[] , between which the point lies that i need.
I can probbaly compute the t-value of those indices that are before and after the point i need, by computing splineLength, length up to the index, and using uniformToNatural.
But where to go from there.. ? I'll probably just try some recursive approximation with an epsilon for biggest error, if i cant figure out anything better.
I wonder how the spline intersection points of the Mograph SplineBoole get computed, as this is more or less the same problem..
