Backlight Shader
On 18/11/2009 at 14:42, xxxxxxxx wrote:
Cinema 4D Version:   11
Platform:   Windows  ;
What kind of shader is a backlight shader? for example when you insert an image you insert a Xbitmap shader...    what would it be for the backlight effect?
Thanks,
~Shawn
On 18/11/2009 at 15:26, xxxxxxxx wrote:
Xtranslucency
Btw. you can get the IDs of all nodes (object, materials, tags, etc.) with GetType(). Simply use the returned ID number to search for the ID string in Cinema's resources.
cheers,
Matthias
