On 17/11/2009 at 15:54, xxxxxxxx wrote:
User Information: Cinema 4D Version: 11 Platform: Windows ; Language(s) : C++ ;
--------- Hello again,
I am trying to insert in image in to the alpha channel of a material that my plugin created.
Here's the code I am attempting to use which is not working.
PluginShader* cloudMap = PluginShader::Alloc(Xbitmap); if (!cloudMap) return FALSE; atmosphereMat->GetDataInstance()->SetLink(MATERIAL_ALPHA_SHADER, cloudMap); cloudMap->SetParameter(BITMAPSHADER_FILENAME,"..\presets\earthCloud_Map.jpg",0); cloudsMat->InsertShader(cloudMap, NULL);
Could someone help me figure out how to insert an image into the alpha channel?
Thanks,
~Shawn
On 17/11/2009 at 16:25, xxxxxxxx wrote:
Relative paths like that won't work. It needs to be either a filename (local to the document file) or a full path. Here are two functions that I use to set and clear the Texture link of a channel using an image. Note that this also sets the related values - you can ignore these if only interested in setting the image file. Also note that this is for a standard Material and not for a shader attached to a Material. Finally, don't forget to do a mat->Update(TRUE, TRUE) after changing all of the material's settings.
// Set Material's Channel Texture Image and other //*---------------------------------------------------------------------------* void PoserMaterial::SetChannelTexture(BaseChannel* bchan, ChannelSampling* samp, const String& map, LONG mix, LONG strength) //*---------------------------------------------------------------------------* { if (!bchan) return; BaseContainer bdata; Filename mapFN = Filename(map); bdata.SetFilename(BASECHANNEL_SUGGESTEDFOLDER, mapFN.GetDirectory()); bchan->SetData(bdata); bdata.SetString(BASECHANNEL_TEXTURE, mapFN.GetFileString()); bchan->SetData(bdata); if (samp->use) { bdata.SetLong(BASECHANNEL_INTERPOLATION, samp->sampling); bchan->SetData(bdata); bdata.SetReal(BASECHANNEL_BLUR_OFFSET, samp->blurOffset*0.1f); bchan->SetData(bdata); Real scale = 1.0f + (Abs(samp->blurScale) * 2.0f); if (samp->blurScale < 0.0f) scale = 1.0f / scale; bdata.SetReal(BASECHANNEL_BLUR_STRENGTH, scale); bchan->SetData(bdata); } else { bdata.SetLong(BASECHANNEL_INTERPOLATION, BITMAPSHADER_INTERPOLATION_ALIAS1); bchan->SetData(bdata); } if (mix) mat->SetParameter(DescID(mix), GeData(MATERIAL_TEXTUREMIXING_MULTIPLY), DESCFLAGS_DONTCHECKMINMAX); if (strength) mat->SetParameter(DescID(strength), GeData(1.0f), DESCFLAGS_DONTCHECKMINMAX); } // Unset Material's Channel Texture Image //*---------------------------------------------------------------------------* void PoserMaterial::UnsetChannelTexture(BaseChannel* bchan, LONG mix, LONG strength) //*---------------------------------------------------------------------------* { if (!bchan) return; BaseContainer bdata; bdata.SetFilename(BASECHANNEL_SUGGESTEDFOLDER, Filename()); bchan->SetData(bdata); bdata.SetString(BASECHANNEL_TEXTURE, ""); bchan->SetData(bdata); if (mix) mat->SetParameter(DescID(mix), GeData(MATERIAL_TEXTUREMIXING_NORMAL), DESCFLAGS_DONTCHECKMINMAX); if (strength) mat->SetParameter(DescID(strength), GeData(1.0f), DESCFLAGS_DONTCHECKMINMAX); }
On 17/11/2009 at 16:45, xxxxxxxx wrote:
so is this the part that sets the filename?
so would I then do this?
cloudMap->SetParameter(BITMAPSHADER_FILENAME,mapFN,0);
of course I would change the name to meet my own needs but you get teh idea..
On 18/11/2009 at 04:03, xxxxxxxx wrote:
The recommended way is to insert the Bitmap shader into the material and then set the texture link. The use of BaseChannels is not recommended anymore, although still working.
BaseMaterial *mat = NULL; mat = doc->GetFirstMaterial(); if(!mat) return FALSE; BaseContainer *data = mat->GetDataInstance(); PluginShader *shd = NULL; shd = PluginShader::Alloc(Xbitmap); if(!shd) return FALSE; BaseContainer *shddata = shd->GetDataInstance(); shddata->SetFilename(BITMAPSHADER_FILENAME, Filename("3punkt.jpg")); //Set here your texture path, relative or absolute doesn't matter shd->Message(MSG_UPDATE); data->SetLink(MATERIAL_ALPHA_SHADER, shd); mat->InsertShader(shd, NULL); mat->Message(MSG_UPDATE); mat->Update(TRUE, TRUE); EventAdd();
On 18/11/2009 at 09:36, xxxxxxxx wrote:
Awesome. Thanks Matthias.. You are the man!
On 18/11/2009 at 13:37, xxxxxxxx wrote:
for a relative path for example lets say the image I want to cal is in "\presets\earth\Cloud_Map.jpg" of the plugin folder would I type it like I did in quotes or a different way?
On 18/11/2009 at 13:43, xxxxxxxx wrote:
nevermind.. I just used "Cloud_Map.jpg" and it worked fine. Thanks again!
