On 17/11/2009 at 04:26, xxxxxxxx wrote:
--------- Hi,
in my PlugIn, I am trying to automatically assign colors to selections of my PolygonObject. I can successfully create the Selections, the Materials and the Texture Tags. Now my problem is the assignment of the texture to the selection.
The item "TEXTURETAG_RESTRICTION" in Ttexture is only a string, and simply setting this string to my selection name seems not work. Is there other means of doing that?
Here's part of my code on the problem:
PolygonObject* op = (PolygonObject* )doc->GetActiveObject(); SelectionTag* opTag = SelectionTag::Alloc(Tpolygonselection); op->InsertTag(opTag, op->GetTag(IDxxx); opTag->SetName(GeLoadString(ID_STRING)); Material* opMat = Material::Alloc(); opMat->SetName(GeLoadString(ID_STRING)); opMat->GetDataInstance()->SetVector(MATERIAL_COLOR_COLOR, Vector(0,0,0)); doc->InsertMaterial(opMat); TextureTag* opTex = TextureTag::Alloc(); op->InsertTag(opTex); opTex->SetMaterial(opMat); opTex->GetDataInstance()->SetString(TEXTURETAG_RESTRICTION, opTag->GetName());
Would appreciate any help on that!
Best regards, Juergen
On 17/11/2009 at 07:52, xxxxxxxx wrote:
Do it this way instead:
opTex->SetParameter(DescID(TEXTURETAG_RESTRICTION), GeData(opTag->GetName()), NULL);
Don't forget to send update messages (opTex->Message(MSG_UPDATE)).
On 18/11/2009 at 07:46, xxxxxxxx wrote:
Thanks. That did it!
