Fresnel Shader in the Color Channel
On 13/11/2009 at 15:37, xxxxxxxx wrote:
Cinema 4D Version:   11
Platform:   Windows  ;
So I have created materials and objects in the plugin that I am working on.   I would like to add the fresnel shader to the COLOR channel and change the colors within that fresnel shader.   Can someone explain to me how this is done?
I have been using :
SetParameter() to set the Color Channel's parameters but the parameter for the color channel that houses the fresnel shader is...
SetParameter(MATERIAL_COLOR_SHADER,?,NULL);
I am not sure what to put for the ? argument..   or if this is even the correct course of action.
Please any help would be greatly appreciated.
Thanks,
~Shawn
On 17/11/2009 at 05:29, xxxxxxxx wrote:
I solved this problem with :
          atmosphereMat->InsertShader(fresnelColor, NULL);
          atmosphereMat->InsertShader(fresnelTrans, NULL);
          atmosphereMat->GetDataInstance()->SetLink(MATERIAL_COLOR_SHADER, fresnelColor);
          atmosphereMat->GetDataInstance()->SetLink(MATERIAL_TRANSPARENCY_SHADER, fresnelTrans);
          fresnelColor->SetParameter(SLA_FRESNEL_GRADIENT,ATMOSPHERIC_COLOR, 0);
          fresnelTrans->SetParameter(SLA_FRESNEL_GRADIENT,Vector (0,0,0), 1);
Now I need to insert color knots into the gradient of the fresnel shader and change their color?
Any idea how to do this?
Thanks,
~Shawn
The Fresnel shader's colors are actually knots of a gradient. They are part of the GradientCustomGui custom GUI and can be accessed through the Gradient custom data type. Please have a look at the GradientShader.cpp SDK example.
cheers,
Matthias
On 17/11/2009 at 05:31, xxxxxxxx wrote:
Thanks Matthias, I will look into that
~Shawn
