On 08/10/2009 at 18:04, xxxxxxxx wrote:
User Information: Cinema 4D Version: 10.506 Platform: Windows ; Mac ; Language(s) : C++ ;
--------- Hey Guys, I have an import filter and I set the values of my preferences through my class' constructor using SetWorldPluginData(). No problems there. I am using GetWorldPluginData() to retrieve these values which kinda works I can get the initial values that I set through my constructor and SetWorldPluginData(). But if I change these values in the Preferences dialog, the next time I use my import filter it looks at the preferences values before I changed them. Now, I know I need to set these changes through SetWorldPluginData but how can I set them to new values if I can't get them correctly from GetWorldPluginData()?
Thanks in advance, Josh
On 12/10/2009 at 08:10, xxxxxxxx wrote:
Has anyone got this to work properly? (i.e bump)
Thanks, Josh
On 12/10/2009 at 08:41, xxxxxxxx wrote:
What kind of filter are you using? A SceneLoaderData plugin for instance uses descriptions and you access the data through the plugins container just like any other NodeData derived plugin.
On 13/10/2009 at 21:28, xxxxxxxx wrote:
Hi Matthias, Yeah the plugin is derived from SceneLoaderData. I am using only description resource files, so I shouldn't have to overload the GetDDescription, GetDParameter, etc. from the parent NodeData class.
I am reading the descriptions from the base container which I get through the GetWorldPluginData() function. Now this does read all of my descriptions properly; but if I open Cinema change any of the values of my descriptions in the preferences, they will not be read correctly until I restart cinema. (i.e they retain the previous entry from the preferences).
So I am just curious on I how I can open Cinema, go into the preferences and change one of the descriptions for my plugin, and then import the data and use the values I just entered into the preferences without restarting Cinema to take affect.
On 14/10/2009 at 02:54, xxxxxxxx wrote:
You don't have to use GetWorldPluginData(). Simply use the scene loader's container.
Example, data is the container:
> \> class STLLoaderData : public SceneLoaderData \> { \> public: \> virtual Bool Init(GeListNode \*node); \> virtual Bool Identify(PluginSceneLoader \*node, const Filename &name;, UCHAR \*probe, LONG size); \> virtual LONG Load(PluginSceneLoader \*node, const Filename &name;, BaseDocument \*doc, LONG filterflags, String \*error, BaseThread \*thread); \> \> static NodeData \*Alloc(void) { return gNew STLLoaderData; } \> }; \> \> Bool STLLoaderData::Init(GeListNode \*node) \> { \> PluginSceneLoader \*loader = (PluginSceneLoader\* )node; \> BaseContainer \*data = loader->GetDataInstance(); \> \> data->SetString(STLFILTER_TEXT, "hello world"); //intialize settings for the first time \> \> return TRUE; \> } \> \> Bool STLLoaderData::Identify(PluginSceneLoader \*node, const Filename &name;, UCHAR \*probe, LONG size) \> { \> PluginSceneLoader \*loader = (PluginSceneLoader\* )node; \> BaseContainer \*data = loader->GetDataInstance(); \> \> //do something \> } \> \> LONG STLLoaderData::Load(PluginSceneLoader \*node, const Filename &name;, BaseDocument \*doc, LONG flags, String \*error, BaseThread \*thread) \> { \> PluginSceneLoader \*loader = (PluginSceneLoader\* )node; \> BaseContainer \*data = loader->GetDataInstance(); \> \> //do something \> } \>
On 14/10/2009 at 17:09, xxxxxxxx wrote:
This worked perfectly! Thanks Matthias.
Josh
