On 09/09/2009 at 03:36, xxxxxxxx wrote:
User Information: Cinema 4D Version: 11.0 Platform: Language(s) : C++ ;
--------- Hi,
I just have a small question. Is it possible to get the index or pointers of selected Keys in a CCurve?
Thanks a lot.
Cheers, Sebastian
On 10/09/2009 at 05:31, xxxxxxxx wrote:
Use GetNBit() and ChangeNBit() with a key to determine and set the selection state in the four avaible timelines. The bits are:
NBIT_TL1_SELECT NBIT_TL2_SELECT NBIT_TL3_SELECT NBIT_TL4_SELECT
On 10/09/2009 at 06:14, xxxxxxxx wrote:
Thanks!!
On 10/09/2009 at 22:35, xxxxxxxx wrote:
Not sure why but when I try using the GetNBit(NBIT_TL1_SELECT) like you mentioned above, I keep getting false returned even though I see the key selected.
Here is a snippet of code
//Set Curr_Key to first found key Curr_Key =Curr_Seq->GetKey(0); //Loop through all the keys on this track while(Curr_Key ) { GePrint(LongToString(Curr_Key->GetTime().GetFrame(GetActiveDocument()->GetFps()))); GePrint(LongToString(Curr_Key->GetNBit(NBIT_TL1_SELECT)));
//When an active key if(Curr_Key->GetNBit(NBIT_TL1_SELECT) || Curr_Key->GetNBit(NBIT_TL2_SELECT) || Curr_Key->GetNBit(NBIT_TL3_SELECT) || Curr_Key->GetNBit(NBIT_TL4_SELECT)) { //DO something GePrint("ENTERED"); }
I have confirmed that the keys exist and the 1st GePrint statement show print the value of their time. But the second one always comes up as zero/false. And I cannot get into the above if statement. Any advice?
On 11/09/2009 at 09:29, xxxxxxxx wrote:
Howdy,
Since GetNBit() is accessing bits, you probably need to do this instead:
> \> GePrint(LongToString(Curr_Key->GetNBit() & NBIT_TL1_SELECT) \>
Adios, Cactus Dan
On 11/09/2009 at 12:47, xxxxxxxx wrote:
DOH! Sorry, I was thinking of a different function, so disregard what I posted above. :o(
On 11/09/2009 at 17:41, xxxxxxxx wrote:
Ok so then I still need help on this one.
On 14/09/2009 at 02:11, xxxxxxxx wrote:
Quote: Originally posted by njt0001 on 11 September 2009 > > * * * > > Ok so then I still need help on this one. > > * * *
Sorry but I can't confirm. This is working fine for me.
> \> Bool MenuTest::Execute(BaseDocument \*doc) \> { \> BaseObject \*op = NULL; \> op = doc->GetActiveObject(); \> if (!op) return FALSE; \> \> CTrack \*track = NULL; \> track = op->GetFirstCTrack(); \> if (!track) return FALSE; \> \> CCurve \*curve = NULL; \> curve = track->GetCurve(CC_CURVE, TRUE); \> if (!curve) return FALSE; \> \> CKey \*key = NULL; \> LONG keycnt = curve->GetKeyCount(); \> \> for (LONG i=0; i<keycnt; i++) \> { \> key = curve->GetKey(i); \> if (!key) return FALSE; \> \> if (key->GetNBit(NBIT_TL1_SELECT)) GePrint("key"+LongToString(i)+" TL1"); \> if (key->GetNBit(NBIT_TL2_SELECT)) GePrint("key"+LongToString(i)+" TL2"); \> if (key->GetNBit(NBIT_TL3_SELECT)) GePrint("key"+LongToString(i)+" TL3"); \> if (key->GetNBit(NBIT_TL4_SELECT)) GePrint("key"+LongToString(i)+" TL4"); \> } \> \> return TRUE; \> } \>
On 14/09/2009 at 08:50, xxxxxxxx wrote:
Oh ok, well I see it when I select a key in keymode, but when I try switching to Fcurve mode it only displays the keys that are selected in Keymode not the keys I select in Fcurve mode. Any thoughts?
Thanks, nate
On 14/09/2009 at 09:06, xxxxxxxx wrote:
For F-Curve keys use these:
NBIT_TL1_SELECT2 NBIT_TL2_SELECT2 NBIT_TL3_SELECT2 NBIT_TL4_SELECT2
At some point these bits will be documented in a proper way. But for now you have to go by the name, they are usally quite self-explanatory.
On 14/09/2009 at 11:06, xxxxxxxx wrote:
Thanks Matthias, that should do it!
