my plugin problems
On 08/09/2009 at 16:51, xxxxxxxx wrote:
Cinema 4D Version:   11
Platform:   Windows  ;
I am wondering why none of my functions do what they are supposed to. The DoCOmmand Function is supposed to subdivide the currently active object, when the command button is clocked, and the draw() is supposed to draw a square polygon if the check box named SHOW_PLANE is checked. Yet nothing is doing what I expect it to.
Here is the code for my entire .cpp file. Does anyone see any reason why my code isn't doing anything?
\>  #include "c4d.h"
\>  #include "c4d_symbols.h"
\>  #include "lib_modeling.h"
\>  #include "c4d_descriptiondialog.h"
\>  #include "sculpttool.h"
\>  #define ID_SCULPTTOOL               1024455
\>  extern Bool AddUndo(BaseDocument* doc, AtomArray* arr, LONG type);
\>  class SculptTool : public DescriptionToolData
\>       DescriptionCommand* data;
\>       LONG buttonPress;
\>       public:
\>            SculptTool();
\>            virtual LONG                    GetToolPluginId() { return ID_SCULPTTOOL; }
\>            virtual const String          GetResourceSymbol() { return String("SculptTool"); }
\>            virtual Bool                    MouseInput(BaseDocument *doc, BaseContainer &data;, BaseDraw *bd, EditorWindow *win, const BaseContainer &msg;);
\>            virtual LONG                    GetState(BaseDocument *doc);
\>            virtual void                    InitDefaultSettings(BaseDocument *doc, BaseContainer &data;);
\>            virtual Bool                    DoCommand(ModelingCommandData &mdat;);
\>            virtual Bool                    GetCursorInfo(BaseDocument *doc, BaseContainer &data;, BaseDraw *bd, Real x, Real y, BaseContainer &bc;);
\>            virtual Bool                    GetDEnabling(BaseDocument *doc, BaseContainer &data;, const DescID &id;,GeData &t;_data,LONG flags,const BaseContainer *itemdesc);
\>            virtual LONG                    Draw(BaseDocument *doc, BaseContainer &data;, BaseDraw *bd, BaseDrawHelp *bh, BaseThread *bt,LONG flags);
\>                      Bool                    Message(BaseDocument* doc, BaseContainer& data, LONG type, void* t_data);
\>       protected:
\>            Bool isdragging;
\>  SculptTool::SculptTool()
\>       isdragging = FALSE;
\>  Bool SculptTool::GetCursorInfo(BaseDocument *doc, BaseContainer &data;, BaseDraw *bd, Real x, Real y, BaseContainer &bc;)
\>       if (bc.GetId()==BFM_CURSORINFO_REMOVE) return TRUE;
\>       bc.SetString(RESULT_BUBBLEHELP, GeLoadString(IDS_HLP_SCULPTTOOL));
\>       return TRUE;
\>  void SculptTool::InitDefaultSettings(BaseDocument *doc, BaseContainer &data;)
\>       //This function sets the default perameters for the Sculpt Tool Options.
\>       BaseObject *op=doc->GetActiveObject();
\>       PolygonObject* objPoly;
\>       objPoly=(PolygonObject* )op;
\>       Vector color;
\>       color = (1,0,0);
\>       GePrint("--------------------------------------------------------");
\>       GePrint(" Sculpt Tool Successfully Loaded!");
\>       DescriptionToolData::InitDefaultSettings(doc,data);
\>       SetMousePointer (MOUSE_PAINTSELECTCIRCLE);
\>       data.SetReal(BRUSH_RADIUS,100);
\>       data.SetReal(SCULPT_STRENGTH,100);
\>       data.SetLong(SCULPT_TYPE, TYPE_SCULPT);
\>       data.SetLong(BRUSH_ORIENTATION, OR_NORMAL);
\>       data.SetLong(MIRROR_PLANE, X_PLANE);
\>       data.SetLong(NUM_SUBDIVISIONS, 1);
\>       data.SetLong(HYPERNURBS_SUBDIVISION, TRUE);
\>       data.SetReal(MAX_ANGLE,pi);
\>       if (objPoly)
\>       data.SetLong(POLYGON_COUNT, objPoly->GetPolygonCount());
\>       else
\>            GePrint ("No Objects in the Scene");
\>  Bool SculptTool::GetDEnabling(BaseDocument *doc, BaseContainer &data;, const DescID &id;,GeData &t;_data,LONG flags,const BaseContainer *itemdesc)
\>       // Enable/disable our parameters
\>       Bool stampBox = data.GetBool(USE_STAMP);
\>       Bool enableMirror = data.GetBool(ENABLE_MIRROR);
\>       BaseObject* op = doc->GetActiveObject();
\>       if (!op)
\>            return false;
\>       switch (id[0].id)
\>       {      case ENABLE_MIRROR:
\>                 if (op->IsInstanceOf(Opolygon))
\>                 {    return TRUE;
\>                 else
\>                 {    return FALSE;
\>             case NUM_SUBDIVISIONS:
\>                 {    return TRUE;
\>                 else
\>                 {    return FALSE;
\>             case HYPERNURBS_SUBDIVISION:
\>                 {    return TRUE;
\>                 else
\>                 {    return FALSE;
\>             case MAX_ANGLE:
\>                 {    return TRUE;
\>                 else
\>                 {    return FALSE;
\>             case POLYGON_COUNT:
\>                 {    return TRUE;
\>                 else
\>                 {    return FALSE;
\>             case SCULPT_TYPE:
\>                 {    return TRUE;
\>                 else
\>                 {    return FALSE;
\>             case COMMAND_SUBDIVIDE:
\>                 {    return TRUE;
\>                 else
\>                 {    return FALSE;
\>             case BRUSH_RADIUS:
\>                 {    return TRUE;
\>                 else
\>                 {    return FALSE;
\>             case SCULPT_STRENGTH:
\>                 {    return TRUE;
\>                 else
\>                 {    return FALSE;
\>             case TOOL_VARIATION:
\>                 {    return TRUE;
\>                 else
\>                 {    return FALSE;
\>             case FALLOFF_CONTROL:
\>                 {    return TRUE;
\>                 else
\>                 {    return FALSE;
\>             case USE_STAMP:
\>                 {    return TRUE;
\>                 else
\>                 {    return FALSE;
\>             case STAMP_IMAGE:
\>                 if (op->IsInstanceOf(Opolygon)&&stampBox;==TRUE)
\>                 {    return TRUE;
\>                 else
\>                 {    return FALSE;
\>             case BRUSH_ORIENTATION:
\>                 {    return TRUE;
\>                 else
\>                 {    return FALSE;
\>             case MIRROR_PLANE:
\>                 if (op->IsInstanceOf(Opolygon)&&enableMirror;==TRUE)
\>                 {    return TRUE;
\>                 else
\>                 {    return FALSE;
\>             case SHOW_PLANE:
\>                 {    return TRUE;
\>                 else
\>                 {    return FALSE;
\>             case PLANE_COLOR:
\>                 {    return TRUE;
\>                 else
\>                 {    return FALSE;
\>       return TRUE;
\>  LONG SculptTool::GetState(BaseDocument *doc)
\>       return CMD_ENABLED;
\>  Bool SculptTool::Message(BaseDocument* doc, BaseContainer& data, LONG type, void* t_data)
\>  switch (type)
\>            case MSG_DESCRIPTION_COMMAND:
\>            DescriptionCommand *dc = (DescriptionCommand* ) t_data;
\>            if (dc->id[0].id==COMMAND_SUBDIVIDE)
\>                 GePrint("Subdivide Button Clicked");
\>                 ModelingCommandData mdat;
\>                 BaseContainer bc;
\>                 mdat.doc = doc;
\>                 mdat.bc = &bc;
\>                 mdat.mode = MODIFY_ALL;
\>              DoCommand(mdat);
\>       return TRUE;
\>  Bool SculptTool::DoCommand(ModelingCommandData &mdat;)
\>  GePrint("In DoCommand");
\>  //CODE RELATED TO THE SUBDIVISION OPTIONS/////////////////////////////////
\>       //Define Variables
\>      PolygonObject *objPoly = ToPoly(mdat.doc->GetActiveObject());
\>       if (!objPoly) return FALSE;
\>       mdat.op = objPoly;
\>       //Determine Attributes
\>       if (mdat.bc->GetBool(HYPERNURBS_SUBDIVISION, TRUE)) //If HyperNURBS is checked
\>       mdat.bc->SetBool(MDATA_SUBDIVIDE_HYPER, TRUE); //Set HyperNURBS subdivision
\>       else
\>       mdat.bc->SetBool(MDATA_SUBDIVIDE_HYPER, FALSE); //Disable HyperNURBS subdivision
\>       mdat.bc->SetLong(MDATA_SUBDIVIDE_SUB, mdat.bc->GetLong(NUM_SUBDIVISIONS)); //Set Number of Subdivisions
\>       mdat.bc->SetReal(MDATA_SUBDIVIDE_ANGLE, mdat.bc->GetReal(MAX_ANGLE)); //Set Maxiumum Angle
\>       //Subdivision Command
\>       SendModelingCommand(MCOMMAND_SUBDIVIDE, mdat);
\>       mdat.bc->SetLong(POLYGON_COUNT, objPoly->GetPolygonCount());//Shows the current polygon count
\>       return TRUE;
\>  //END SUBDIVISION OPTIONS/////////////////////////////////////////////////
\>       GePrint("End Of DoCommand");
\>  LONG SculptTool::Draw(BaseDocument *doc, BaseContainer &data;, BaseDraw *bd, BaseDrawHelp *bh, BaseThread *bt,LONG flags)
\>            PolygonObject *op = ToPoly(doc->GetActiveObject());
\>          LONG lngMySymPlane =doc->GetDataInstance()->GetLong (MIRROR_PLANE);
\>          LONG trans = 175;
\>          Vector color = data.GetVector(PLANE_COLOR);
\>          //Matrix for determining scale, rotation, and position.
\>          Matrix m = op->GetMg();
\>          Vector rad = op->GetRad();
\>          m.v1 *= rad.x+100;
\>          m.v2 *= rad.y+100;
\>          m.v3 *= rad.z+100;
\>          switch (lngMySymPlane)
\>                 case Z_PLANE:
\>                 if (doc->GetDataInstance()->GetBool(SHOW_PLANE)) // If SHOW_PLANE is checked, then draw the polygon.
\>                      GePrint("Z_PLANE");
\>                 Vector p[4];
\>                 p[0] = Vector(-1,-1,0);
\>                 p[1] = Vector(-1,1,0);
\>                 p[2] = Vector(1,1,0);
\>                 p[3] = Vector(1,-1,0);
\>                 p[0] = p[0] * m;
\>                 p[1] = p[1] * m;
\>                 p[2] = p[2] * m;
\>                 p[3] = p[3] * m;
\>                 Vector f[3] = { Vector(color),Vector(color),Vector(color)};
\>                 bd->SetLightList(BDRAW_SETLIGHTLIST_NOLIGHTS);
\>                 bd->SetTransparency(trans);
\>                 bd->Polygon3D(p,f,TRUE);
\>                 return true;
\>                 else //If SHOW_PLANE is unchecked, stop drawing the polygon.
\>                 Vector p[4] = { Vector(0,0,0),Vector(0,0,0),Vector(0,0,0),Vector(0,0,0)};
\>                 Vector f[3] = { Vector(0,0,0),Vector(0,0,0),Vector(0,0,0)};
\>                 bd->Polygon3D(p,f,FALSE);
\>              return DRAW_HANDLES|DRAW_AXIS;
\>                 break;
\>                 case X_PLANE:
\>                 GePrint("X_PLANE");
\>                 Vector p[4];
\>                 p[0] = Vector(0,-1,-1);
\>                 p[1] = Vector(0,-1,1);
\>                 p[2] = Vector(0,1,1);
\>                 p[3] = Vector(0,1,-1);
\>                 p[0] = p[0] * m;
\>                 p[1] = p[1] * m;
\>                 p[2] = p[2] * m;
\>                 p[3] = p[3] * m;
\>                 return true;
\>                 break;
\>                 case Y_PLANE:
\>                 GePrint("Y_PLANE");
\>                 Vector p[4];
\>                 p[0] = Vector(-1,0,-1);
\>                 p[1] = Vector(-1,0,1);
\>                 p[2] = Vector(1,0,1);
\>                 p[3] = Vector(1,0,-1);
\>                 p[0] = p[0] * m;
\>                 p[1] = p[1] * m;
\>                 p[2] = p[2] * m;
\>                 p[3] = p[3] * m;
\>                 return true;
\>                 break;
\>       return TRUE;
\>  Bool SculptTool::MouseInput(BaseDocument *doc, BaseContainer &data;, BaseDraw *bd, EditorWindow *win, const BaseContainer &msg;)
\>       if (!doc) return FALSE;
\>       Real mx = msg.GetReal(BFM_INPUT_X);
\>       Real my = msg.GetReal(BFM_INPUT_Y);
\>       Real mz = msg.GetReal(BFM_INPUT_Z);
\>       LONG button;
\>       switch (msg.GetLong(BFM_INPUT_CHANNEL))
\>            case BFM_INPUT_MOUSELEFT : button=KEY_MLEFT; break;
\>            case BFM_INPUT_MOUSERIGHT: button=KEY_MRIGHT; break;
\>            default: return TRUE;
\>       Real dx, dy;
\>       BaseContainer device;
\>       win->MouseDragStart(button,mx,my,MOUSEDRAG_DONTHIDEMOUSE|MOUSEDRAG_NOMOVE);
\>       while (win->MouseDrag(&dx;,&dy;,&device;)==MOUSEDRAG_CONTINUE)
\>       GePrint("Mouse's X Position is: " + RealToString(mx));
\>       GePrint("Mouse's Y Position is: " + RealToString(my));
\>       GePrint("Mouse's Z Position is: " + RealToString(mz));
\>       return TRUE;
\>  Bool RegisterSculptTool()
\>       return RegisterToolPlugin(ID_SCULPTTOOL, GeLoadString(IDS_SCULPTTOOL), 0, GeLoadString(IDS_HLP_SCULPTTOOL), gNew SculptTool);
On 08/09/2009 at 17:39, xxxxxxxx wrote:
1. DoCommand() already exists as a virtual function. It is called explicitly by SendModelingCommand(). I would rename the function if you are calling it from Message() to avoid issues.
2. The edgecuttool example calls the modeling function from MouseInput(). Of course, this will depend upon what you are doing. If your tool doesn't require mouse input, then it doesn't need to do that there.
3. You are trying to store values in 'bc' attached to mdat but both of these are local variables and go away as soon as Message() exits. If you want to retain the values stored in 'bc', you will need to make it a member of your SculptTool class.
4. Call this at the end of your InitDefaultSettings() :
   Call this at the end of your GetDEnabling() :
return DescriptionToolData::GetDEnabling(doc,data,id,t_data,flags,itemdesc);
5. Why are you getting your tool's description values from doc->GetDataInstance() in Draw()? The BaseContainer is sent as 'data'.
On 08/09/2009 at 18:03, xxxxxxxx wrote:
so for you third point.
I should add :
to the SculptTool Class?
~Shawn
On 08/09/2009 at 18:16, xxxxxxxx wrote:
okay got the draw plane to work by changing everything to data.
but it only refreshes if I make a change to the viewport, like zoom in or something. How can I make the viewport update after the draw() code is executed?
Thanks,
~Shawn
On 08/09/2009 at 18:53, xxxxxxxx wrote:
Okay here's the code now..   The draw() function works great now..
The Subdivide() function previously the DoCommand () still does nothing.
Any thoughts?
\>  #include "c4d.h"
\>       public:
\>            SculptTool();
\>            Bool                              Subdivide(ModelingCommandData &mdat;);
\>       protected:
\>            Bool isdragging;
\>       return TRUE;
\>       Vector color;
\>       color = Vector (0,1,0);
\>       data.SetVector(PLANE_COLOR,color);
\>       if (objPoly)
\>       else
\>       if (!op)
\>            return false;
\>                 {    return TRUE;
\>                 else
\>                 {    return FALSE;
\>                 {    return TRUE;
\>                 else
\>                 {    return FALSE;
\>                 {    return TRUE;
\>                 else
\>                 {    return FALSE;
\>             case MAX_ANGLE:
\>                 {    return TRUE;
\>                 else
\>                 {    return FALSE;
\>                 {    return TRUE;
\>                 else
\>                 {    return FALSE;
\>                 {    return TRUE;
\>                 else
\>                 {    return FALSE;
\>                 {    return TRUE;
\>                 else
\>                 {    return FALSE;
\>                 {    return TRUE;
\>                 else
\>                 {    return FALSE;
\>                 {    return TRUE;
\>                 else
\>                 {    return FALSE;
\>                 {    return TRUE;
\>                 else
\>                 {    return FALSE;
\>                 {    return TRUE;
\>                 else
\>                 {    return FALSE;
\>             case USE_STAMP:
\>                 {    return TRUE;
\>                 else
\>                 {    return FALSE;
\>                 {    return TRUE;
\>                 else
\>                 {    return FALSE;
\>                 {    return TRUE;
\>                 else
\>                 {    return FALSE;
\>                 {    return TRUE;
\>                 else
\>                 {    return FALSE;
\>             case SHOW_PLANE:
\>                 {    return TRUE;
\>                 else
\>                 {    return FALSE;
\>                 {    return TRUE;
\>                 else
\>                 {    return FALSE;
\>       return TRUE;
\>  return DescriptionToolData::GetDEnabling(doc,data,id,t_data,flags,itemdesc);
\>  switch (type)
\>                 mdat.doc = doc;
\>                 mdat.bc = &bc;
\>              Subdivide(mdat);
\>       return TRUE;
\>       return TRUE;
\>  Bool SculptTool::Subdivide(ModelingCommandData &mdat;)
\>  GePrint("In Subdivide");
\>       else
\>       return TRUE;
\>       GePrint("End Of Subdivide");
\>          LONG lngMySymPlane =data.GetLong (MIRROR_PLANE);
\>                 case Z_PLANE:
\>                 if (data.GetBool(SHOW_PLANE)) // If SHOW_PLANE is checked, then draw the polygon.
\>                 Vector p[4];
\>                 p[0] = p[0] * m;
\>                 p[1] = p[1] * m;
\>                 p[2] = p[2] * m;
\>                 p[3] = p[3] * m;
\>                      EventAdd(EVENT_FORCEREDRAW);
\>                 return true;
\>                 break;
\>                 case X_PLANE:
\>                 Vector p[4];
\>                 p[0] = p[0] * m;
\>                 p[1] = p[1] * m;
\>                 p[2] = p[2] * m;
\>                 p[3] = p[3] * m;
\>                 return true;
\>                 break;
\>                 case Y_PLANE:
\>                 Vector p[4];
\>                 p[0] = p[0] * m;
\>                 p[1] = p[1] * m;
\>                 p[2] = p[2] * m;
\>                 p[3] = p[3] * m;
\>                 return true;
\>                 break;
\>       return TRUE;
\>       LONG button;
\>       Real dx, dy;
\>       return TRUE;
\>       return TRUE;
On 08/09/2009 at 19:04, xxxxxxxx wrote:
You'll have to remove the definition of ModelCommandData mdat and BaseContainer bc from Message(). Local variables always override more global variables.
Do you actually get the GePrint() in Message() when the button is clicked?
On 08/09/2009 at 19:12, xxxxxxxx wrote:
yes I get the GePrint from Message() That says "Subdivide Button Clicked" I also get the first GePrint from Subdivide() that says "In Subdivide" I do not get the one at the end of Subdivide that says " End of Subdivide.
On 08/09/2009 at 19:15, xxxxxxxx wrote:
okay when I remove the definitions of ModelCommandData mdat and BaseContainer bc from Message(), c4d crashes when I click the button.
~Shawn
On 08/09/2009 at 19:16, xxxxxxxx wrote:
scratch that.. it doesn't crash anymore..   but still does nothing.. :(
On 08/09/2009 at 19:19, xxxxxxxx wrote:
GePrint("End Of Subdivide"); shows up now because I moved it above return TRUE;
Seems like it's running the code in Subdivide() but it's not effecting the object.
On 08/09/2009 at 20:29, xxxxxxxx wrote:
Yeah, I was going to mention that the "End of Subdivide" would never print. :)
The only thing that I can think of is that the object isn't really a Polygon object. For something like subdivision it must be. But if it is, then I'm at a loss. One thing to check is if SendModelingCommand() is succeeding or failing (if (!SendModelingCommand(...)). Another is to verify that the document is not a clone. Many times, Cinema 4D passes a clone of the document (like for rendering or generator plugins). I couldn't imagine this for a tool but best to verify, verify, verify!
On 08/09/2009 at 20:37, xxxxxxxx wrote:
How can I make sure that the object is really a polygon object?
On 08/09/2009 at 20:46, xxxxxxxx wrote:
if (objPoly->IsInstanceOf(Opolygon)) // It's a polygon object ;)
On 09/09/2009 at 02:52, xxxxxxxx wrote:
Here's the Subdivide function with a few new checks in there...
\>  if (objPoly->IsInstanceOf(Opolygon))
\>       GePrint("It's a Polygon");
\>  else
\>       GePrint ("It's not a polygon");
\>       return FALSE;
\>       else
\>       if (!SendModelingCommand(MCOMMAND_SUBDIVIDE, mdat))
\>            GePrint("FAILURE");
\>       else
\>            GePrint("SUCCESS");
\>       return TRUE;
In the console I get
\>  Subdivide Button Clicked
\>  In Subdivide
\>  It's a Polygon
\>  SUCCESS
\>  End of Subdivide
But still it does not subdivide the current polygon object in the scene.
Anyone know why this is? SEE above for other code in the plugin.
On 09/09/2009 at 18:30, xxxxxxxx wrote:
okay so I stripped it back down to just the message() and the DoCommand () code looks like this.
\>  switch (type)
\>                 mdat.doc = doc;
\>                 mdat.bc = &bc;
\>                 mdat.op = op;
\>              DoCommand(mdat);
\>       return TRUE;
\>       return TRUE;
Now when I click the button, the object subdivides.
but I have no control over the attributes.
When I try to add in the following.
\>       else
\>       mdat.bc->SetLong(MDATA_SUBDIVIDE_SUB, bc->GetLong(NUM_SUBDIVISIONS)); //Set Number of Subdivisions
It won't recognize the attributes and won't subdivide at all. Must be something in the way I am using the base container.   Any thoughts about this? Anyone know how I could edit the first code to be able to adjust subdivision attributes from the NUM_SUBDIVISIONS long and the MAX_ANGLE real?
Thanks,
~Shawn
On 10/09/2009 at 01:22, xxxxxxxx wrote:
Don't pass the BaseContainder from Message() to mdat.
Do something like this:
BaseContainer bc;
bc.SetLong(MDATA_SUBDIVIDE_SUB, data.GetLong(NUM_SUBDIVISIONS));
bc.SetReal(MDATA_SUBDIVIDE_ANGLE,data.GetReal(MDATA_SUBDIVIDE_ANGLE));
mdat.doc = doc;
mdat.bc = &bc;
mdat.op = op; //pass the pointer to the object
SendModelingCommand(MCOMMAND_SUBDIVIDE, cd));
cheers,
Matthias
On 10/09/2009 at 02:58, xxxxxxxx wrote:
LOL...   it's always so simple.    Thanks, Matthias.. works like a charm now.
~Shawn
