Refresh Generator Object
On 08/09/2009 at 08:03, xxxxxxxx wrote:
Cinema 4D Version: R11
Platform: Windows ; Mac OSX ;
Hi,in the GetVirtualObject-method i create a PolgonObject with some values.
If i change the values, the viewport doesn't refresh. I have to click somewhere in the interface and then it refreshs.
I tried it with something like this.>
\> op->Message(MSG_UPDATE);//and MSG_CHANGE \> EventAdd(EVENT_FORCEREDRAW); \>
I also tried
DrawViews(DA_ONLY_ACTIVE_VIEW|DA_NO_THREAD|DA_NO_ANIMATION); //DrawViews(DA_NO_THREAD|DA_FORCEFULLREDRAW);
I even overwrote the Message-method of the GeneratorObject without success.
If i catch the MSG_GETCUSTOMICON-message in the Message-method and call EventAdd(EVENT_FORCEREDRAW); there, it works. But i don't like this dirty hack and i don't want to refresh everytime.
Anybody an idea what i could try else?
Thanks!
cheers,
Oli
On 08/09/2009 at 08:07, xxxxxxxx wrote:
It's hard to say, please post some simplified code showing the problem.
cheers,
Matthias
On 09/09/2009 at 02:17, xxxxxxxx wrote:
Ok, here some codesnips
\> //GetVirtualObjects \> BaseObject\* AixObject::GetVirtualObjects(PluginObject \*op, HierarchyHelp \*hh){ \> \> Bool dirty = op->CheckCache(hh) || op->IsDirty(DIRTY_DATA); \> \> if (!dirty){ \> \> return op->GetCache(hh); \> } \> \> BaseContainer \*objectData = op->GetDataInstance(); \> \> BaseObject \*ret = BaseObject::Alloc(Onull); \> \> if (!ret){ \> \> blDelete(ret); \> return NULL; \> } \> \> //...create PolygonObjects or SplineObjects \> \> Free(polygonObject); \> Free(splineObject); \> segmentPoints.Free(); \> \> //refresh \> EventAdd(EVENT_FORCEREDRAW); \> DrawViews(DA_ONLY_ACTIVE_VIEW|DA_NO_THREAD|DA_NO_ANIMATION); //Tried this too DrawViews(DA_NO_THREAD|DA_FORCEFULLREDRAW); \> \> return ret; \> } \>
I also tried this.
\> //GetVirtualObjects \> BaseObject\* AixObject::GetVirtualObjects(PluginObject \*op, HierarchyHelp \*hh){ \> //same as above \> \> //refresh \> op->Message(MSG_UPDATE); //tried also MSG_CHANGE \> \> return ret; \> } \> \> //Message \> Bool AixObject::Message(GeListNode \*node, LONG type, void \*t_data){ \> \> if (type == MSG_UPDATE) \> { \> EventAdd(EVENT_FORCEREDRAW); \> DrawViews(DA_ONLY_ACTIVE_VIEW|DA_NO_THREAD|DA_NO_ANIMATION); \> //DrawViews(DA_NO_THREAD|DA_FORCEFULLREDRAW); \> } \> \> } \>
cheers,
Oli
On 10/09/2009 at 05:37, xxxxxxxx wrote:
You have to send the MSG_UPDATE message to the polygon object. Also please check the RoundedTube SDK example as this is a parametric generator which creates a polygon object.
cheers,
Matthias
