Strange Crashing
On 07/09/2009 at 08:18, xxxxxxxx wrote:
Cinema 4D Version:   11
Platform:   Windows  ;
I am trying to get a command button to call a certain function. This is Tool plugin.
Here's the code in the message() which looks for the command button to be clicked.
\>  Bool SculptTool::Message(BaseDocument* doc, BaseContainer& data, LONG type, void* t_data)
\>  switch (type)
\>            case MSG_DESCRIPTION_COMMAND:
\>            DescriptionCommand *dc = (DescriptionCommand* ) t_data;
\>            if (dc->id[0].id==COMMAND_SUBDIVIDE)
\>                 GePrint("Subdivide Button Clicked");
\>                 ModelingCommandData mdat;
\>                 BaseContainer bc;
\>                 mdat.bc = &bc;
\>              DoCommand(mdat);
\>       return TRUE;
Here's the code in the DoCommand()
\>  Bool SculptTool::DoCommand(ModelingCommandData &mdat;)
\>  GePrint("In DoCommand");
\>  //CODE RELATED TO THE SUBDIVISION OPTIONS/////////////////////////////////
\>       //Define Variables
\>      PolygonObject *objPoly = ToPoly(mdat.doc->GetActiveObject());
\>       if (!objPoly) return FALSE;
\>       //Determine Attributes
\>       if (mdat.bc->GetBool(HYPERNURBS_SUBDIVISION, TRUE)) //If HyperNURBS is checked
\>       mdat.bc->SetBool(MDATA_SUBDIVIDE_HYPER, TRUE); //Set HyperNURBS subdivision
\>       else
\>       mdat.bc->SetBool(MDATA_SUBDIVIDE_HYPER, FALSE); //Disable HyperNURBS subdivision
\>       mdat.bc->SetLong(MDATA_SUBDIVIDE_SUB, mdat.bc->GetLong(NUM_SUBDIVISIONS)); //Set Number of Subdivisions
\>       mdat.bc->SetReal(MDATA_SUBDIVIDE_ANGLE, mdat.bc->GetReal(MAX_ANGLE)); //Set Maxiumum Angle
\>       //Subdivision Command
\>       SendModelingCommand(MCOMMAND_SUBDIVIDE, mdat);
\>       mdat.bc->SetLong(POLYGON_COUNT, objPoly->GetPolygonCount());
\>       return TRUE;
\>  //END SUBDIVISION OPTIONS/////////////////////////////////////////////////
For some reason, C4D crashes whenever I click the command button. I get the "GePrint" message that says "InCommand" so I know the problem is happening in the DoCommand(). Or at least I think that's where it's happening.
Does anyone have any ideas as to what would be causing C4D to crash?
Thanks,
~Shawn
On 07/09/2009 at 09:09, xxxxxxxx wrote:
This line probably points to an empty document pointer.
PolygonObject *objPoly = ToPoly(mdat.doc- >GetActiveObject());
Always check for valid pointers!
Fill the ModelingCommandData with the current document.
cheers,
Matthias
On 07/09/2009 at 09:18, xxxxxxxx wrote:
would I do that with something like this?
BaseDocument* doc;
     mdat.doc = doc;
On 07/09/2009 at 09:27, xxxxxxxx wrote:
No, in this case you would simply pass the doc from the Message function.
> \> Bool SculptTool::Message(BaseDocument\* doc, BaseContainer & data, LONG type, void\* t_data) \> { \>      ... \>       \>      mdat.doc = doc; \>       \>      ... \> } \>
cheers,
Matthias
On 07/09/2009 at 09:32, xxxxxxxx wrote:
Awesome. Okay now it doesn't crash, but the problem now is.. it doesn't do anything. . LOL I still get the "In DoCOmmand" message, so it is doing the command. but none of the code in DoCommand() is executing?
Any thoughts there?
Thanks a lot Matthias.
~Shawn
On 07/09/2009 at 10:36, xxxxxxxx wrote:
Any thoughts on why it's not doing anything?
Thanks,
~Shawn
On 07/09/2009 at 11:45, xxxxxxxx wrote:
Since SendModelingCommand() works on objects, you MUST specify the object in ModelingCommandData:
mdat->op = objPoly;
Otherwise it doesn't do anything, yes. 🙂
On 07/09/2009 at 12:55, xxxxxxxx wrote:
okay I did that and it still does nothing. 😞 Any thoughts? I added
mdat->op = objPoly;
Here's new code for DoCommand()
\>       mdat.op = objPoly;
\>       else
\>       mdat.bc->SetLong(POLYGON_COUNT, objPoly->GetPolygonCount());//Shows the current polygon count
\>       return TRUE;
\>       GePrint("End Of DoCommand");
On 07/09/2009 at 13:57, xxxxxxxx wrote:
Have you checked the values being set in mdat, especially MDATA_SUBDIVIDE_SUB? This must be >0. mdat.mode should be MODIFY_ALL.
On 07/09/2009 at 14:36, xxxxxxxx wrote:
okay nothing happens when I click the button. But something very weird happens when I click the button and then resize the viewport frame. I click the button, nothing happens, then I resize the viewport frame and suddenly the cube in my viewport subdivides. But not by the number that is in the LONG NUM_SUBDIVISIONS. I am not sure where it is getting this number from ..
Here's the code I have in DoCommand().
Thanks for your help.
\>       mdat.mode = MODIFY_ALL;
\>       else
\>       mdat.bc->SetLong(MDATA_SUBDIVIDE_SUB, mdat.bc->GetLong(NUM_SUBDIVISIONS); //Set Number of Subdivisions
\>       return TRUE;
Weird huh?
