TranslationMaps and polygons
    On 07/09/2009 at 03:54, xxxxxxxx wrote:
    Cinema 4D Version:   10.5
    Platform:
    I am getting some results when using the TranslationMaps for polygons that I cannot explain.
    When you delete an ngon that consists of two or more polygons, the information that is passed in the translation maps is not what I would expect.
    here is a code snippet I use in the Message member of a tag plugin.
    > <code>
    \>  if (type==MSG_TRANSLATE_POLYGONS)
    \>       {     // Update the indexes as needed
    \>            BaseContainer *bc=((BaseList2D* )node)->GetDataInstance();
    \>            if (!bc)
    \>                 return false;
    \>            LONG lngI,lngJ,lngSize;
    \>            TranslationMaps *map;
    \>            map=(TranslationMaps* )data;
    \>            if (map)
    \>                 // New to old polygon mapping
    \>                 if (arrNewToOldPoly)
    \>                      GeFree(arrNewToOldPoly);
    \>                 lngSize = sizeof(LONG) * map->m_nPolygonCount;
    \>                 arrNewToOldPoly = (LONG* )GeAlloc(lngSize);
    \>                 if (!arrNewToOldPoly)
    \>                      return false;
    \>                 for (lngI=0;lngI<map->m_nPolygonCount;lngI++)
    \>                 {     if (lngI>=map->m_oPolygonCount)
    \>                      {     arrNewToOldPoly[lngI]=-1;
    \>                      else
    \>                      {     arrNewToOldPoly[lngI]=lngI;}
    \>                 for (lngJ=0;lngJ<map->m_mPolygonCount;lngJ++)
    \>                      GePrint("New To Old "+LongToString(map->m_pPolygonMap[lngJ].nIndex)+" "+LongToString(map->m_pPolygonMap[lngJ].oIndex)+" "+LongToString(map->m_pPolygonMap[lngJ].lFlags));
    \>                      if ((map->m_pPolygonMap[lngJ].lFlags & TRANSMAP_FLAG_NEW))
    \>                      {     arrNewToOldPoly[map->m_pPolygonMap[lngJ].nIndex]=-1;
    \>                      if ((map->m_pPolygonMap[lngJ].lFlags & TRANSMAP_FLAG_MOVED))
    \>                      {     if (map->m_pPolygonMap[lngJ].nIndex != -1)
    \>                           {     arrNewToOldPoly[map->m_pPolygonMap[lngJ].nIndex]=map->m_pPolygonMap[lngJ].oIndex;
    \>                 // Old to new polygon mapping
    \>                 if (arrOldTonewPoly)
    \>                      GeFree(arrOldTonewPoly);
    \>                 lngSize = sizeof(LONG) * map->m_oPolygonCount;
    \>                 arrOldTonewPoly = (LONG* )GeAlloc(lngSize);
    \>                 if (!arrOldTonewPoly)
    \>                      return false;
    \>                 for (lngI=0;lngI<map->m_oPolygonCount;lngI++)
    \>                 {     arrOldTonewPoly[lngI]=lngI;
    \>                 {     GePrint("Old To New "+LongToString(map->m_pPolygonMap[lngJ].nIndex)+" "+LongToString(map->m_pPolygonMap[lngJ].oIndex)+" "+LongToString(map->m_pPolygonMap[lngJ].lFlags));
    \>                      if ((map->m_pPolygonMap[lngJ].lFlags & TRANSMAP_FLAG_DELETED))
    \>                      {     arrOldTonewPoly[map->m_pPolygonMap[lngJ].oIndex]=-1;
    \>                      {     arrOldTonewPoly[map->m_pPolygonMap[lngJ].oIndex]=map->m_pPolygonMap[lngJ].nIndex;
    > </code>
    Now if use some simple polygon objects (I started with a cube with 2 segments), and do some simple tests this is what I get:
    Delete a single polygon:
    Highest polygon index is 23, the index of the polygon that gets deleted is 7
    The polygon mapping gives this
    nIndex -1 oIndex 7 lFlags 8 (TRANSMAP_FLAG_DELETED)
    nIndex 7 oIndex 23 lFlags 4 (TRANSMAP_FLAG_MOVED)
    That makes perfect sense but if I try to delete a ngon that consists of 2 polygons things are not that clear
    Delete a ngon:
    Highest polygon index is 26, the indexes of the polygons that make up the ngon are 25 and 7
    nIndex 7 oIndex 26 lFlags 4 (TRANSMAP_FLAG_MOVED)
    nIndex -1 oIndex 28 lFlags 8 (TRANSMAP_FLAG_DELETED)
    So the mapping tells me that polygon 25 (old index) has not been changed, although it does not exist any more
    and both polygon 26 and 7 (old index) are now both polygon 7 (new index) although the original 7 has been deleted.
    Is this a bug or am I missing something?
    Nebu
