On 29/08/2009 at 08:41, xxxxxxxx wrote:
--------- Here's the code I am using. I am trying to get the MDATA_SUBDIVIDE_SUB to pull the number that is entered in to the NUM_SUBDIVISIONS text box to set the number of subdivisions.
I keep getting this error.
subdivisiontool.cpp(80) : error C2664: 'String::StringToLong' : cannot convert parameter 1 from 'String' to 'LONG *'
Anyone have any thoughts?
Thanks,
~Shawn
\> \> LONG amount; \> String subAmount; \> subAmount = mdat.bc->GetString(NUM_SUBDIVISIONS); \> amount = String::StringToLong (subAmount); \> \> //Determine Attributes \> \> if (mdat.bc->GetBool(HYPERNURBS_SUBDIVISION, TRUE)) //If HyperNURBS is checked \> { \> mdat.bc->SetBool(MDATA_SUBDIVIDE_HYPER, TRUE); \> } \> else \> { \> mdat.bc->SetBool(MDATA_SUBDIVIDE_HYPER, FALSE); \> } \> mdat.bc->SetLong(MDATA_SUBDIVIDE_SUB, subAmount); \> mdat.bc->SetReal(MDATA_SUBDIVIDE_ANGLE, pi); \> \> //Subdivision Command \> SendModelingCommand(MCOMMAND_SUBDIVIDE, mdat); \> \> return true; \> \>
On 29/08/2009 at 10:22, xxxxxxxx wrote:
Need more information/code. What is NUM_SUBDIVISIONS defined as in the description resource file (.res)? It would be easier to define it as LONG and then simply get LONG amount = mdat.bc->GetLong(NUM_SUBDIVISIONS).
I'm not sure why you are getting this value from a ModelingCommandData. Wouldn't it be something entered by the user into the dialog associated with the tool plugin?
On 29/08/2009 at 20:11, xxxxxxxx wrote:
okay I ended up just using a LONG instead of a string. so that worked well. Now I'd like to set the default value of a LONG field to contain the number of polygons in the object.
This is the code I am using to set my default values.
\> void SubdivisionTool::InitDefaultSettings(BaseDocument *doc, BaseContainer &data;) \> { \> //This function sets the default perameters for the Subdivision Options. \> PolygonObject* objPoly; \> objPoly=(PolygonObject* )doc; \> \> DescriptionToolData::InitDefaultSettings(doc,data); \> data.SetLong(NUM_SUBDIVISIONS, 1); \> data.SetLong(HYPERNURBS_SUBDIVISION, TRUE); \> data.SetReal(MAX_ANGLE, 180); \> data.SetLong(POLYGON_COUNT, objPoly->GetPolygonCount()); \> \> \> } \> \>
Setting the polygon count is not working.. What am I doing wrong. This learning curve is killing me. LOL
On 29/08/2009 at 21:02, xxxxxxxx wrote:
Solved it thanks,
