Subdivide
    On 03/09/2009 at 20:41, xxxxxxxx wrote:
    After you get objPoly, check that it isn't NULL:
    if (!objPoly) return FALSE;
    Also, make sure that the mdat.bc is set to a BaseContainer. I'd do this in Message after declaring mdat. Declare a BaseContainer and add it:
    BaseContainer bc;
    mdat.bc = bc;
    You may also want to set your input BaseContainer value (HYPERNURBS_SUBDIVISION).
    On 03/09/2009 at 20:59, xxxxxxxx wrote:
    now I have this in Message()
    \>  Bool SculptTool::Message(BaseDocument* doc, BaseContainer& data, LONG type, void* t_data)
    \>  switch (type)
    \>            case MSG_DESCRIPTION_COMMAND:
    \>            DescriptionCommand *dc = (DescriptionCommand* ) t_data;
    \>            if (dc->id[0].id==COMMAND_SUBDIVIDE)
    \>                 GePrint("Subdivide Button Clicked");
    \>                 ModelingCommandData mdat;
    \>                 BaseContainer* bc;
    \>                 mdat.bc = bc;
    \>              DoCommand(mdat);
    \>       return TRUE;
    and this is the error.
    warning C4700: uninitialized local variable 'bc' used
    I assume there is more I have to do to the basecontainer.
    ~Shawn
    On 03/09/2009 at 21:19, xxxxxxxx wrote:
    Don't use a pointer to it, just declare it as I did above. :)
    On 03/09/2009 at 21:25, xxxxxxxx wrote:
    hmm.. now I get this.
    error C2440: '=' : cannot convert from 'BaseContainer' to 'BaseContainer *'
    after changing
    BaseContainer* bc;
    to
    BaseContainer bc;
    On 03/09/2009 at 21:37, xxxxxxxx wrote:
    mdat.bc = &bc;
    That will do it.
    On 03/09/2009 at 21:43, xxxxxxxx wrote:
    yes it did. Thanks a lot Robert.
    Off to bed now.
    Thanks for your help.
    ~Shawn
