userdata work around
    On 27/08/2009 at 05:57, xxxxxxxx wrote:
    Cinema 4D Version:   10.5
    Platform:      Mac OSX  ;
    Hi
    I was hoping to find a way of gathering up all my userdata from a null to put into an array, but I saw from the forum that coffee might not support this
    <<"I'd like to check if an object has user data(s) , how many , and their name . Do you think it's possible in coffee ?">>
    is there a work around for this? could I make a null with one userdata field, then copy and paste as many as I need and in my coffee script loop through all the nulls of the same name to find out how many userdata fields there are, or is there a much simpler way?
    Kind regards Conor
    On 27/08/2009 at 07:27, xxxxxxxx wrote:
    Hi I've just been looking at kattkieru's post about "BaseContainer and user data". I have a null with two user data fields (one is 56 the other 24) and I've tried the code
    main(doc,op)
    var op = doc->FindObject("userdata");
    var bc = op->GetContainer();
    var i = 0;
    while (bc->GetIndexId(i) != NOTOK)
    println(bc->GetIndexData(i));
    i++;
    but I get
    0
    10.000000
    1.000000
    0
    [Object-0x17a1d32c]
    in the console window, have I completely misunderstood this code if I'm expecting it to print the contents of the user data?
    Kind regards Conor
    On 27/08/2009 at 08:01, xxxxxxxx wrote:
    It's not possible to iterate through userdata in COFFEE.
    Userdata can only be accessed directly in COFFEE, like this: var data = op#ID_USERDATA:1
    The only workaround is described in this thread:
    some COFFEE questions
    For full userdata access you have to use the C++ API.
    cheers,
    Matthias
    On 27/08/2009 at 08:12, xxxxxxxx wrote:
    Thanks Matthias, I'll give that a go.
    cheers
    Conor
