set frame
On 24/08/2009 at 06:35, xxxxxxxx wrote:
Cinema 4D Version:
Platform: Mac OSX ;
Language(s) : C.O.F.F.E.E ;---------
Hi I know that this is probably very simple, but I'm afraid I'm not getting it. I'm trying to write a coffee tag pluggin and to fill an array. I want to use a loop to scroll through the frames and fill the user data info for each frame.
I've tried:var i = 0;
for (i = 0; i < max_frame; i = i + 1) {
BaseTime (i,25);
doc->SetTime();print (frame);
print (",");
print( arr_number[frame]);
println(" "); }but I'm not having any joy. Any help would be greatly appreciated.
Regards Conor
On 24/08/2009 at 06:49, xxxxxxxx wrote:
Do something like this:
\> var i = 0; \> \> for (i = 0; i < 50; i++) \> { \> var time = new(BaseTime); \> time->SetFrame(i,25.0); \> doc->SetTime(time); \> } \>
cheers,
Matthias
On 24/08/2009 at 07:22, xxxxxxxx wrote:
Thanks Matthias, I've tried this but its still not doing what I expected, instead of printing each frame and its user data, it prints out the current frame and its user date ,again and again, for the length of the loop.
Is there a simpler way to fill an array ( made up of each frame and its user data)?
On 24/08/2009 at 07:29, xxxxxxxx wrote:
If I understand you correctly you want to fill an array with user data for each frame. If so then i think a COFFEE tag is not the best way to do it. Have you looked into writing a COFFEE script or MenuPlugin instead?
cheers,
Matthias
On 24/08/2009 at 07:32, xxxxxxxx wrote:
No. I'll start reading up on this now.
Cheers Conor
On 24/08/2009 at 07:37, xxxxxxxx wrote:
The thing is a COFFEE tag is an expression which is called for eachframe and every change you make. A script or MenuPlugin is called just once by the user.
Btw. if you use SetTime() you also have to call AnimateDocument() to actually animate the document.
cheers,
Matthias
