GetVirtualObjects() and textures
On 21/08/2009 at 15:52, xxxxxxxx wrote:
Cinema 4D Version: R10-R11
Platform: Windows ; Mac OSX ;
I'm having a bit of a rough time keeping the Texture tags' Materials on objects returned through GetVirtualObjects(). There is way too much code to post an example, so I'll explain as best as possible.My Generator plugin uses a library of objects which exist in the same document. If I simply clone the library objects and insert them into a Null object which is part of what is returned by GetVirtualObjects(), they retain their Texture tag material links. But then the user gets the joy of hundreds of objects (thousands, millions - literally, I'm doing a multi-threaded generator!) when they make it editable (or as part of the cache for rendering and such). In order to 'organize' that I've been connecting them into one conglomerate polygon object using SendModelingCommand(MCOMMAND_JOIN) with a temporary document containing a Null object under which they are all childed.
Now, this retains the Texture tags (etc.) but the Material links are broken thereafter. Since this conglomerate can be a mix of many different library objects it would be impossible for me to reconnect them without explicit information (which is lost after the connect obviously).
It seems that doing the connect in this temporary document is enough to break the links. Would it be advisable to copy the Materials (temporarily for the connect call) into this document in hopes that the links will remain? Or will the Texturetag<->Material links need to be temporarily stored so as to be reestablished after the connect?
Thanks,
On 21/08/2009 at 16:06, xxxxxxxx wrote:
I don't if this helps in your case but check the MarkMaterials structure and the MSG_MULTI_MARKMATERIALS message description in the SDK docu. It is used to duplicate materials and update the links if you for instance copy generators with internal material links.
cheers,
Matthias
On 24/08/2009 at 12:55, xxxxxxxx wrote:
No idea about the MarkMaterials structure but what worked was this:
Since the cloned objects are returned individually (childed to a Null object) and these retain the proper Material links, an AtomArray is filled with the Materials from them before MCOMMAND_JOIN. Then they are relinked afterwards on the result to reduced Texture tags (duplicates removed). Works perfectly.
