Container IDs for RenderData
On 04/08/2009 at 14:10, xxxxxxxx wrote:
Cinema 4D Version:
Platform:
Language(s) :---------
In may COFFEE script many of the container ids for RenderData are not defined (like RDATA_NAME). Do I need some include directive?RDATA_ALPHACHANNEL is defined though, so
\> renderdata()->GetContainer()->GetData(RDATA_VOLUMETRICLIGHTING) \>
works. But
\> renderdata()->GetContainer()->GetData(RDATA_NAME) \>
works not. Any ideas?
On 04/08/2009 at 14:22, xxxxxxxx wrote:
The following
\> MyMenuPlugin::Execute(scene) \> { \> var rd = scene->GetFirstRenderData(); \> println(rd); \> scene->SetActiveRenderData(rd); // this fails \> } \>
also fails with an runtime error:
(9) Member not found
Not sure if this is somehow related.
I'm using Cinema 4d R11 on Windows (!). Any ideas?
On 05/08/2009 at 02:29, xxxxxxxx wrote:
RDATA_NAME is not defined anymore. Please use renderdata->GetName().
To set the active render data you set its bit BIT_ACTIVERENDERDATA, rdata->SetBit(BIT_ACTIVERENDERDATA).
Unfortunatly there seem to be some bugs for the COFFEE class. Setting the bit doesn't work always as expected. Also it's currently only a 2D list not a hierarchy. You can't step through a whole render settings hierarchy.
I have reported this to the CINEMA 4D developers.
cheers,
Matthias
On 05/08/2009 at 03:00, xxxxxxxx wrote:
So is C.O.F.F.E.E. suggested for plug-in development or should I prefer the C++ API? I chose COFFEE because:
* I do not need a compiler (yes, I'm developing on a virtualized windows box from my linux host, so this is a point)
* I guessed it will speed up my code-test-debug cycle
What I see so far is, that the documentation is not in sync with the C.O.F.F.E.E. API (or did I miss something).
Will I be happy with C.O.F.F.E.E. in the long term? Is there a way to tell what is in the API and what not (like I could do by looking up in C/C++-Header files?).
Cheers;)
On 05/08/2009 at 03:06, xxxxxxxx wrote:
It really depends on the type of plugin you are developing. In general the C++ API is much more complete and powerful. Also you can't create COFFEE plugins with a Attribute Manager interface.
Personally I only use COFFEE to write some scripts and do prototyping (testing algorithms etc.).
cheers,
Matthias
On 05/08/2009 at 04:31, xxxxxxxx wrote:
> * * *What I tried worked so far, only the "Render Settings" dialog does not get updated in real-time. What did not work for you?
