On 01/08/2009 at 03:22, xxxxxxxx wrote:
User Information: Cinema 4D Version: R11 Platform: Windows ; Language(s) : C++ ;
--------- Hi everyone,
I'm new here, but I've written some COFFEE plugins and am now resurrecting my old C++ skills. I have a question about building plugins.
I've successfully built the SDK example plugin. I understand that for my own plugs, I can copy the cinema4dsdk folder and use that as a base. However, that means recompiling the API code for each new plugin.
Is it acceptable to compile the API code to a static library and link to that? This would avoid having to add the _api project to each solution. I've tried it and it works fine, but are there any problems waiting down the line if I do this? Or is this what everyone does anyway?
I'd be very interested in any comments.
On 04/08/2009 at 12:33, xxxxxxxx wrote:
The API is always built into a static library. Xcode sometimes rebuilds it but it can be referenced in the link section of the build environment. It is built into the resource\api_lib\ folder. Make sure to select the correct build target (release or debug) and then the associated api.lib.
On 04/08/2009 at 14:48, xxxxxxxx wrote:
Thanks Robert. That's good because I'd prefer to compile the library once then link to the api.lib for new plugins.
Good to know that's okay to do.
Steve
