SDK and Visual C++
    On 29/07/2009 at 19:06, xxxxxxxx wrote:
    Cinema 4D Version:
    Platform:
    Language(s) :
    Hello, I am using visual C++ and am trying to load the SDK in to VC++. It keeps telling me that there is an error loading the SDK. I think I may have corrupted it or something like that. Is it possible to get a fresh copy of the SDK? Not just the documentation.    And, is there something special I need to do to be able to load the SDK in to VC++?
    Thanks,
    ~Shawn
    On 29/07/2009 at 20:20, xxxxxxxx wrote:
    Not enough information. Are you doing this in 32-bit or 64-bit? What version of Cinema 4D?
    If you are using R11, you need at least Visual Studio 2005 and to use the .vcproj file. You cannot build in 64-bit using the Express version of VS!
    Again, more information is necessary to understand the problem. I had no problem whatsoever loading the project and building it in one go without errors or warnings.
    On 29/07/2009 at 22:03, xxxxxxxx wrote:
    I am using Cinema 4D version 11.. I am using Visual C++ Epress edition 2008. 32 bit..   I did click on the vcproj file and can open it.. but when I try to build this is the errors I am getting.
    Sorry I was not specific before.
    ~Shawn
    ------ Rebuild All started: Project: _api, Configuration: Debug Win32 ------
    Deleting intermediate and output files for project '_api', configuration 'Debug|Win32'
    Compiling...
    c4d_basechannel.cpp
    c4d_basecontainer.cpp
    c4d_basedocument.cpp
    c4d_basedraw.cpp
    c4d_baseeffectorplugin.cpp
    c4d_baselist.cpp
    c4d_basematerial.cpp
    c4d_baseobject.cpp
    c4d_baseplugin.cpp
    c4d_baseselect.cpp
    c4d_basesound.cpp
    c4d_basetag.cpp
    c4d_basetime.cpp
    c4d_bitmapfilter.cpp
    c4d_canimation.cpp
    c4d_coffee.cpp
    c4d_commandplugin.cpp
    c4d_ctrackplugin.cpp
    c4d_customdatatype.cpp
    c4d_customdatatypeplugin.cpp
    Generating Code...
    Compiling...
    c4d_customguidata.cpp
    c4d_customguiplugin.cpp
    c4d_descriptiondialog.cpp
    c4d_falloffplugin.cpp
    c4d_file.cpp
    c4d_filterplugin.cpp
    c4d_gedata.cpp
    c4d_general.cpp
    c4d_gl.cpp
    c4d_gui.cpp
    c4d_library.cpp
    c4d_listview.cpp
    c4d_materialplugin.cpp
    c4d_memory.cpp
    c4d_messageplugin.cpp
    c4d_nodeplugin.cpp
    c4d_objectplugin.cpp
    c4d_painter.cpp
    c4d_particleobject.cpp
    c4d_pmain.cpp
    Generating Code...
    Compiling...
    c4d_quaternion.cpp
    c4d_resource.cpp
    c4d_scenehookplugin.cpp
    c4d_shaderplugin.cpp
    c4d_string.cpp
    c4d_tagplugin.cpp
    c4d_thread.cpp
    c4d_toolplugin.cpp
    c4d_tools.cpp
    c4d_videopost.cpp
    c4d_videopostplugin.cpp
    ge_ieee.cpp
    ge_sort.cpp
    operatingsystem.cpp
    customgui_base.cpp
    customgui_bitmapbutton.cpp
    customgui_datetime.cpp
    customgui_descproperty.cpp
    customgui_description.cpp
    customgui_fontchooser.cpp
    Generating Code...
    Compiling...
    customgui_gradient.cpp
    customgui_htmlviewer.cpp
    customgui_hyperlink.cpp
    customgui_inexclude.cpp
    customgui_linkbox.cpp
    customgui_listview.cpp
    customgui_matassign.cpp
    customgui_matpreview.cpp
    customgui_movieview.cpp
    customgui_pla.cpp
    customgui_priority.cpp
    customgui_quicktab.cpp
    customgui_splinecontrol.cpp
    customgui_texbox.cpp
    lib_activeobjectmanager.cpp
    lib_aes.cpp
    lib_browser.cpp
    lib_ca.cpp
    lib_clipmap.cpp
    lib_cloud.cpp
    Generating Code...
    Compiling...
    lib_collider.cpp
    lib_description.cpp
    lib_dwgobjects.cpp
    lib_editortools.cpp
    lib_filtertree.cpp
    lib_hair.cpp
    lib_iconcollection.cpp
    lib_layershader.cpp
    lib_modeling.cpp
    lib_ngon.cpp
    lib_noise.cpp
    lib_prefs.cpp
    lib_regexpr.cpp
    lib_sds.cpp
    lib_selectionchanger.cpp
    lib_sn.cpp
    lib_snapping.cpp
    lib_snd.cpp
    lib_splinehelp.cpp
    lib_viewport.cpp
    Generating Code...
    Compiling...
    lib_zipfile.cpp
    filter_prefs.cpp
    filterpreview.cpp
    filterthread.cpp
    linefetchutil.cpp
    matrixrotate.cpp
    matrixutil.cpp
    matrixwrapper.cpp
    pixelfetchutil.cpp
    sdk_add.cpp
    mergelin.cpp
    miniblt.cpp
    scale.cpp
    scaleitf.cpp
    scalelin.cpp
    c4d_graphview.cpp
    c4d_operatorplugin.cpp
    c4d_particles.cpp
    ge_mtools.cpp
    c4d_basebitmap.cpp
    Generating Code...
    Creating library...
    Project : warning PRJ0018 : The following environment variables were not found:
    $(WebDeployPath)
    Build log was saved at "file://C:\Program Files\MAXON\CINEMA 4D R11\plugins\cinema4dsdk\obj\_api\Win32_Debug\BuildLog.htm"
    _api - 0 error(s), 0 warning(s)
    ------ Rebuild All started: Project: cinema4dsdk, Configuration: Debug Win32 ------
    Deleting intermediate and output files for project 'cinema4dsdk', configuration 'Debug|Win32'
    Compiling...
    Blinker.cpp
    c:\program files\maxon\cinema 4d r11\resource\c4d_symbols.h(1079) : error C2143: syntax error : missing '}' before 'constant'
    c:\program files\maxon\cinema 4d r11\resource\c4d_symbols.h(2876) : error C2143: syntax error : missing ';' before '}'
    c:\program files\maxon\cinema 4d r11\resource\c4d_symbols.h(2876) : error C2059: syntax error : '}'
    c:\program files\maxon\cinema 4d r11\resource\c4d_symbols.h(2903) : error C2143: syntax error : missing '}' before 'constant'
    c:\program files\maxon\cinema 4d r11\resource\c4d_symbols.h(2903) : error C2143: syntax error : missing ';' before 'constant'
    c:\program files\maxon\cinema 4d r11\resource\c4d_symbols.h(2903) : error C2059: syntax error : 'constant'
    c:\program files\maxon\cinema 4d r11\resource\c4d_symbols.h(5205) : error C2143: syntax error : missing ';' before '}'
    c:\program files\maxon\cinema 4d r11\resource\c4d_symbols.h(5205) : error C2059: syntax error : '}'
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\animation\blinker.cpp(118) : error C2065: 'IDS_BLINKER' : undeclared identifier
    FilterMatrix.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\bitmapfilter\filtermatrix.cpp(143) : error C2065: 'IDS_MATRIX' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\bitmapfilter\filtermatrix.cpp(431) : error C2065: 'IDS_APPLY_FILTER' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\bitmapfilter\filtermatrix.cpp(469) : error C2065: 'DLG_SMPL_MATRIX' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\bitmapfilter\filtermatrix.cpp(470) : error C2065: 'GADGET_SMPL_MATRIX_PREVIEWGROUP' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\bitmapfilter\filtermatrix.cpp(479) : error C2065: 'GADGET_SMPL_MATRIX_DOCUMENT_PREVIEW' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\bitmapfilter\filtermatrix.cpp(480) : error C2065: 'GADGET_SMPL_MATRIX_TEXTURE_MODE' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\bitmapfilter\filtermatrix.cpp(482) : error C2065: 'GADGET_SMPL_MATRIX_SLIDER_MIX' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\bitmapfilter\filtermatrix.cpp(483) : error C2065: 'GADGET_SMPL_MATRIX_SLIDER_ANGLE' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\bitmapfilter\filtermatrix.cpp(484) : error C2065: 'GADGET_SMPL_MATRIX_TYPE_POPUP' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\bitmapfilter\filtermatrix.cpp(498) : error C2065: 'GADGET_SMPL_MATRIX_TYPE_POPUP' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\bitmapfilter\filtermatrix.cpp(498) : error C2051: case expression not constant
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\bitmapfilter\filtermatrix.cpp(515) : error C2065: 'GADGET_SMPL_MATRIX_SLIDER_ANGLE' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\bitmapfilter\filtermatrix.cpp(515) : error C2051: case expression not constant
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\bitmapfilter\filtermatrix.cpp(531) : error C2065: 'GADGET_SMPL_MATRIX_SLIDER_MIX' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\bitmapfilter\filtermatrix.cpp(531) : error C2051: case expression not constant
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\bitmapfilter\filtermatrix.cpp(547) : error C2065: 'GADGET_SMPL_MATRIX_TEXTURE_MODE' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\bitmapfilter\filtermatrix.cpp(547) : error C2051: case expression not constant
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\bitmapfilter\filtermatrix.cpp(554) : error C2065: 'GADGET_SMPL_MATRIX_DOCUMENT_PREVIEW' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\bitmapfilter\filtermatrix.cpp(554) : error C2051: case expression not constant
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\bitmapfilter\filtermatrix.cpp(560) : warning C4060: switch statement contains no 'case' or 'default' labels
    FilterThreshold.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\bitmapfilter\filterthreshold.cpp(108) : error C2065: 'IDS_THRESHOLD' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\bitmapfilter\filterthreshold.cpp(380) : error C2065: 'IDS_APPLY_FILTER' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\bitmapfilter\filterthreshold.cpp(632) : error C2065: 'DLG_THRESHOLD' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\bitmapfilter\filterthreshold.cpp(633) : error C2065: 'GADGET_THRESHOLD_PREVIEWGROUP' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\bitmapfilter\filterthreshold.cpp(642) : error C2065: 'GADGET_THRESHOLD_DOCUMENT_PREVIEW' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\bitmapfilter\filterthreshold.cpp(643) : error C2065: 'GADGET_THRESHOLD_SLIDER_LEVELS' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\bitmapfilter\filterthreshold.cpp(658) : error C2065: 'GADGET_THRESHOLD_SLIDER_LEVELS' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\bitmapfilter\filterthreshold.cpp(658) : error C2051: case expression not constant
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\bitmapfilter\filterthreshold.cpp(667) : error C2065: 'GADGET_THRESHOLD_DOCUMENT_PREVIEW' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\bitmapfilter\filterthreshold.cpp(667) : error C2051: case expression not constant
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\bitmapfilter\filterthreshold.cpp(673) : warning C4060: switch statement contains no 'case' or 'default' labels
    paint_saver_test.cpp
    BFF.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\filter\bff.cpp(110) : error C2065: 'IDS_BFF' : undeclared identifier
    STL.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\filter\stl.cpp(408) : error C2065: 'IDS_STL' : undeclared identifier
    ActiveObject.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\activeobject.cpp(723) : error C2065: 'IDS_ACTIVEOBJECT' : undeclared identifier
    AsyncTest.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\asynctest.cpp(233) : error C2065: 'IDS_INTERPOLATION' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\asynctest.cpp(240) : error C2065: 'IDS_NONE' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\asynctest.cpp(241) : error C2065: 'IDS_LINEAR' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\asynctest.cpp(242) : error C2065: 'IDS_EXPUP' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\asynctest.cpp(243) : error C2065: 'IDS_EXPDOWN' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\asynctest.cpp(244) : error C2065: 'IDS_SMOOTH' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\asynctest.cpp(246) : error C2065: 'IDS_POSITION' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\asynctest.cpp(664) : error C2065: 'IDS_ASYNCTEST' : undeclared identifier
    GradientUserArea.cpp
    layershaderbrowser.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\layershaderbrowser.cpp(134) : error C2065: 'IDD_SHADER_BROWSER' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\layershaderbrowser.cpp(137) : error C2065: 'IDC_LAYER_BROWSER_LINK' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\layershaderbrowser.cpp(138) : error C2065: 'IDC_LAYER_BROWSER_TREE' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\layershaderbrowser.cpp(159) : error C2065: 'IDC_LAYER_BROWSER_LINK' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\layershaderbrowser.cpp(159) : error C2051: case expression not constant
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\layershaderbrowser.cpp(165) : warning C4065: switch statement contains 'default' but no 'case' labels
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\layershaderbrowser.cpp(312) : error C2065: 'IDC_LAYER_BROWSER_PROPS' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\layershaderbrowser.cpp(358) : error C2065: 'IDS_LAYER_SHADER_BROWSER' : undeclared identifier
    ListView.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\listview.cpp(73) : error C2065: 'DLG_LISTVIEW' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\listview.cpp(77) : error C2065: 'GADGET_LISTVIEW1' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\listview.cpp(78) : error C2065: 'GADGET_LISTVIEW2' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\listview.cpp(88) : error C2065: 'GADGET_INSERT' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\listview.cpp(89) : error C2065: 'GADGET_REMOVE' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\listview.cpp(156) : error C2065: 'GADGET_LISTVIEW1' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\listview.cpp(156) : error C2051: case expression not constant
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\listview.cpp(157) : error C2065: 'GADGET_LISTVIEW2' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\listview.cpp(157) : error C2051: case expression not constant
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\listview.cpp(184) : error C2065: 'GADGET_INSERT' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\listview.cpp(184) : error C2051: case expression not constant
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\listview.cpp(235) : error C2065: 'GADGET_REMOVE' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\listview.cpp(235) : error C2051: case expression not constant
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\listview.cpp(252) : warning C4060: switch statement contains no 'case' or 'default' labels
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\listview.cpp(293) : error C2065: 'IDS_LISTVIEW' : undeclared identifier
    MemStat.cpp
    MenuTest.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\menutest.cpp(90) : error C2065: 'IDS_MENUTEST' : undeclared identifier
    Serial.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\serial.cpp(47) : error C2065: 'IDC_SERIALNUMBER' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\serial.cpp(53) : error C2065: 'IDC_SERIALNUMBER' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\serial.cpp(55) : error C2065: 'IDC_SERIALNUMBER' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\serial.cpp(64) : error C2065: 'DLG_REGISTER' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\serial.cpp(71) : error C2065: 'IDC_SERIALNUMBER' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\serial.cpp(82) : error C2065: 'IDC_SERIALNUMBER' : undeclared identifier
    SubDialog.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\subdialog.cpp(172) : error C2065: 'DLG_SUBDIALOG' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\subdialog.cpp(176) : error C2065: 'GADGET_SUBDIALOG' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\subdialog.cpp(195) : error C2065: 'GADGET_SUB1' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\subdialog.cpp(195) : error C2051: case expression not constant
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\subdialog.cpp(198) : error C2065: 'GADGET_SUBDIALOG' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\subdialog.cpp(199) : error C2065: 'GADGET_SUBDIALOG' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\subdialog.cpp(204) : error C2065: 'GADGET_SUB2' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\subdialog.cpp(204) : error C2051: case expression not constant
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\subdialog.cpp(207) : error C2065: 'GADGET_SUBDIALOG' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\subdialog.cpp(208) : error C2065: 'GADGET_SUBDIALOG' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\subdialog.cpp(212) : warning C4060: switch statement contains no 'case' or 'default' labels
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\gui\subdialog.cpp(253) : error C2065: 'IDS_SUBDIALOG' : undeclared identifier
    Atom.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\object\atom.cpp(310) : error C2065: 'IDS_ATOM_POINT' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\object\atom.cpp(311) : error C2065: 'IDS_ATOM_EDGE' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\object\atom.cpp(484) : error C2065: 'IDS_ATOM' : undeclared identifier
    Circle.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\object\circle.cpp(258) : error C2065: 'IDS_CIRCLE' : undeclared identifier
    dropeffector.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\object\dropeffector.cpp(149) : error C2065: 'IDS_DROPEFFECTOR' : undeclared identifier
    gl_test_object.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\object\gl_test_object.cpp(7) : fatal error C1083: Cannot open include file: 'dbasedraw.h': No such file or directory
    Gravitation.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\object\gravitation.cpp(90) : error C2065: 'IDS_GRAVITATION' : undeclared identifier
    Generating Code...
    Compiling...
    hair_collision.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\object\hair_collision.cpp(168) : error C2065: 'IDS_HAIR_COLLIDER_EXAMPLE' : undeclared identifier
    hair_constraint.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\object\hair_constraint.cpp(102) : error C2065: 'IDS_HAIR_CONSTRAINT_EXAMPLE' : undeclared identifier
    hair_deformer.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\object\hair_deformer.cpp(155) : error C2065: 'IDS_HAIR_DEFOMER_EXAMPLE' : undeclared identifier
    hair_force.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\object\hair_force.cpp(111) : error C2065: 'IDS_HAIR_FORCE_EXAMPLE' : undeclared identifier
    hair_generator.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\object\hair_generator.cpp(145) : error C2065: 'IDS_HAIR_GENERATOR_EXAMPLE' : undeclared identifier
    hair_grass.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\object\hair_grass.cpp(292) : error C2065: 'IDS_HAIR_GRASS_EXAMPLE' : undeclared identifier
    MorphMixer.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\object\morphmixer.cpp(84) : error C2065: 'IDS_MORPHSELECT' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\object\morphmixer.cpp(143) : error C2065: 'IDS_IMPORTFAILED' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\object\morphmixer.cpp(314) : error C2065: 'IDS_MORPHMIXER' : undeclared identifier
    noiseeffector.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\object\noiseeffector.cpp(120) : error C2065: 'IDS_NOISEEFFECTOR' : undeclared identifier
    RoundedTube.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\object\roundedtube.cpp(458) : error C2065: 'IDS_ROUNDED_TUBE' : undeclared identifier
    Spherify.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\object\spherify.cpp(200) : error C2065: 'IDS_SPHERIZE' : undeclared identifier
    Triangulate.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\object riangulate.cpp(88) : error C2065: 'IDS_TRIANGULATE' : undeclared identifier
    BitmapDistortionShader.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\shader\bitmapdistortionshader.cpp(120) : error C2065: 'IDS_BITMAPDISTORTION' : undeclared identifier
    GradientShader.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\shader\gradientshader.cpp(222) : error C2065: 'IDS_SDKGRADIENT' : undeclared identifier
    hair_shader.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\shader\hair_shader.cpp(78) : error C2065: 'IDS_HAIR_SHADER_EXAMPLE' : undeclared identifier
    Illumination.cpp
    MandelbrotShader.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\shader\mandelbrotshader.cpp(127) : error C2065: 'IDS_MANDELBROT' : undeclared identifier
    ParticleVolume.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\shader\particlevolume.cpp(279) : error C2065: 'IDS_PARTICLEVOLUME' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\shader\particlevolume.cpp(280) : error C2065: 'IDS_PARTICLEVOLUME_HIGH_DENSITY' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\shader\particlevolume.cpp(282) : error C2065: 'IDS_PARTICLEVOLUME_LOW_DENSITY' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\shader\particlevolume.cpp(331) : error C2065: 'IDS_PARTICLEVOLUME' : undeclared identifier
    SimpleMaterial.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\shader\simplematerial.cpp(257) : error C2065: 'IDS_SIMPLEMATERIAL' : undeclared identifier
    hair_render.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source ag\hair_render.cpp(139) : error C2065: 'IDS_HAIR_RENDERING_EXAMPLE' : undeclared identifier
    hair_styling.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source ag\hair_styling.cpp(115) : error C2065: 'IDS_HAIR_STYLING_EXAMPLE' : undeclared identifier
    Generating Code...
    Compiling...
    LookAtCamera.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source ag\lookatcamera.cpp(102) : error C2065: 'IDS_LOOKATCAMERA' : undeclared identifier
    edgecuttool.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source ool\edgecuttool.cpp(105) : error C2065: 'IDS_HLP_EDGECUT_SDK' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source ool\edgecuttool.cpp(721) : error C2065: 'IDS_EDGECUT_SDK' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source ool\edgecuttool.cpp(721) : error C2065: 'IDS_HLP_EDGECUT_SDK' : undeclared identifier
    LiquidTool.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source ool\liquidtool.cpp(126) : error C2065: 'IDS_PRIMITIVETOOL' : undeclared identifier
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source ool\liquidtool.cpp(214) : error C2065: 'IDS_PRIMITIVETOOL' : undeclared identifier
    reversenormals.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source ool\reversenormals.cpp(149) : error C2065: 'IDS_REVERSE_NORMALS_SDK' : undeclared identifier
    hair_videopost.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\videopost\hair_videopost.cpp(90) : error C2065: 'IDS_HAIR_VIDEOPOST_EXAMPLE' : undeclared identifier
    VPColorize.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\videopost\vpcolorize.cpp(163) : error C2065: 'IDS_VIDEOPOST' : undeclared identifier
    VPInvertImage.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\videopost\vpinvertimage.cpp(197) : error C2065: 'IDS_VPINVERTIMAGE' : undeclared identifier
    VPReconstructImage.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\videopost\vpreconstructimage.cpp(80) : error C2065: 'IDS_VPRECONSTRUCT' : undeclared identifier
    VPVisualizeNormals.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\videopost\vpvisualizenormals.cpp(81) : error C2065: 'IDS_VPVISUALIZEPOST' : undeclared identifier
    datatype.cpp
    randomfalloff.cpp
    c:\program files\maxon\cinema 4d r11\plugins\cinema4dsdk\source\falloff\randomfalloff.cpp(56) : error C2065: 'IDS_RANDOMFALLOFF' : undeclared identifier
    Main.cpp
    Generating Code...
    $(WebDeployPath)
    Build log was saved at "file://C:\Program Files\MAXON\CINEMA 4D R11\plugins\cinema4dsdk\obj\cinema4dsdk\Win32_Debug\BuildLog.htm"
    cinema4dsdk - 500 error(s), 5 warning(s)
    ========== Rebuild All: 1 succeeded, 1 failed, 0 skipped ==========
    On 29/07/2009 at 22:09, xxxxxxxx wrote:
    This is just from trying to build the files that come with cinema4dsdk.vcproj
    I didn't alter the files at all.
    Not sure what is happening or what I am doing wrong.
    Thanks for your help.
    ~Shawn
    On 29/07/2009 at 22:20, xxxxxxxx wrote:
    Make sure you are building the cinema4Dsdk project and not simply the api library. I don't see any references to the cinema4dsdk files in your build log. It is possible that the api library build will not succeed under the project settings for the plugin project. I just built the Debug 32-bit in VS 2005 with no warnings or errors using the "Build Solution" option.
    It is good practice to "Rebuild Solution" whenever you have already built as it automatically cleans the solution before rebuilding.
    You should build the API library through the cinema4dsdk 'plugin' found in the plugins\cinema4dsdk folder. ETA: I see that you are trying to do that.
    On 29/07/2009 at 22:31, xxxxxxxx wrote:
    I just used the "Build Solution" option and I get these results.
    ------ Build started: Project: cinema4dsdk, Configuration: Debug Win32 ------
    Compiling...
    Blinker.cpp
    FilterMatrix.cpp
    FilterThreshold.cpp
    BFF.cpp
    STL.cpp
    ActiveObject.cpp
    AsyncTest.cpp
    ListView.cpp
    MemStat.cpp
    MenuTest.cpp
    Serial.cpp
    SubDialog.cpp
    Atom.cpp
    Circle.cpp
    dropeffector.cpp
    gl_test_object.cpp
    Gravitation.cpp
    hair_collision.cpp
    hair_constraint.cpp
    Generating Code...
    Compiling...
    hair_deformer.cpp
    hair_force.cpp
    hair_generator.cpp
    hair_grass.cpp
    MorphMixer.cpp
    noiseeffector.cpp
    RoundedTube.cpp
    Spherify.cpp
    Triangulate.cpp
    GradientShader.cpp
    hair_shader.cpp
    ParticleVolume.cpp
    SimpleMaterial.cpp
    hair_render.cpp
    hair_styling.cpp
    LookAtCamera.cpp
    edgecuttool.cpp
    LiquidTool.cpp
    Generating Code...
    Compiling...
    reversenormals.cpp
    hair_videopost.cpp
    VPColorize.cpp
    VPInvertImage.cpp
    datatype.cpp
    randomfalloff.cpp
    Main.cpp
    Generating Code...
    $(WebDeployPath)
    ========== Build: 0 succeeded, 1 failed, 1 up-to-date, 0 skipped ==========
    On 29/07/2009 at 22:40, xxxxxxxx wrote:
    It's weird.. the API succeeds but the cinema4dsdk does not.
    On 30/07/2009 at 01:06, xxxxxxxx wrote:
    VS 2008 is currently not officially supported by MAXON.
    Anyway what you can try is to go to WebDeployment for VS 2008, this will install WebDeployment for VS 2008 which is missing by default in VS 2008.
    Another way to work around is to go to "CINEMA 4D R11\resource\_api_lib" and open "DebugWin32.vsprops" in a text editor. Change all occurences of "$(WebDeployPath)" with "..\..\resource" (without the quotation marks).
    cheers,
    Matthias
    On 30/07/2009 at 13:26, xxxxxxxx wrote:
    I did the things you memntioned and still the the errors I posted above.. THis is a bit frustrating. LOL.. Other people over at c4dcafe have said they were able to build the samples with vC++ express edition 2008..
    Not sure what I am doing wrong.
    Any other thoughts as to why the above errors would be happening?    The second set that I posted.
    Thanks,
    ~Shawn
