Howto create layerobject
On 22/07/2009 at 14:39, xxxxxxxx wrote:
Cinema 4D Version: 10.5
Platform: Windows ;
Howto create LayerObject?
First wrong
BaseObject\* lay = BaseObject::Alloc(Olayer); \> (!lay) return FALSE; // return null pointer \> lay->SetName(LayNameString); \> doc->InsertObject(lay,NULL,NULL,FALSE);
Second wrong
LayerObject\* lay = LayerObject::Alloc(); \> (!lay) return FALSE; // Good \> lay->SetName(LayNameString); \> doc->InsertObject((BaseObject\* )lay,NULL,NULL,FALSE);//Crash
Please help.
On 22/07/2009 at 14:56, xxxxxxxx wrote:
Hi dinnye,
The LayerObject has nothing to do with BaseObject. See class hierarchy.
What you want to do?
Bye, Sebastian
On 22/07/2009 at 15:12, xxxxxxxx wrote:
Hi Shawni
I want create layer in the Layer Browser (and assign to object (later))
My code
Bool AC4DPOLY::CreateLayer (BaseDocument \*mydoc, String LayNameString) \> { \> GeListHead \*layerlist = NULL; \> layerlist = mydoc->GetLayerObjectRoot(); \> if(!layerlist) return FALSE; \> Bool laycheck =TRUE; \> \> //check current layerlist \> LayerObject \*layer = (LayerObject\* )layerlist->GetFirst(); \> if (layer) \> { \> for (layer; layer; layer = layer->GetNext()) \> { \> if (LayNameString == layer->GetName()) \> { \> laycheck = FALSE; \> break; \> } \> } \> } \> \> //Create layer \> if (laycheck) \> { \> //Create layer with LayNameString name; \> } \> \> return TRUE; \> }
Dont know howto alloc LayerObject, not sample in SDK.
Sorry my bad english.Thanks
Dinnye
On 22/07/2009 at 16:18, xxxxxxxx wrote:
LayerObject* lo = LayerObject::Alloc();
if (!lo) // allocation failedI see you tried doc->InsertObject(). You probably need to get the layer root (doc->GetLayerObjectRoot()) and append to the list (GeListHead->InsertLast(lo)).
Set an object to the layer using obj->SetLayerObject(lo).
Use lo->GetLayerData(doc,...) to get the layer settings.
About all that I can tell you about layers. :D
On 23/07/2009 at 01:12, xxxxxxxx wrote:
Thanks. Try this.
On 23/07/2009 at 02:05, xxxxxxxx wrote:
Yes, you have to insert the layer into the layer's list.
Simple example, inserts a layer:
\> Bool MenuTest::Execute(BaseDocument \*doc) \> { \> LayerObject \*layer = NULL; \> layer = LayerObject::Alloc(); \> if (!layer) return FALSE; \> \> GeListHead \*layerlist = NULL; \> layerlist = doc->GetLayerObjectRoot(); \> if (!layerlist) return FALSE; \> \> layerlist->Insert(layer, NULL, NULL); \> \> layerlist->Message(MSG_UPDATE); \> \> EventAdd(); \> \> return TRUE; \> } \>
cheers,
Matthias
On 23/07/2009 at 03:26, xxxxxxxx wrote:
wow, cool!
Thanks Matthias.
