On 29/06/2009 at 18:27, xxxxxxxx wrote:
User Information: Cinema 4D Version: R10-R11 Platform: Windows ; Mac OSX ; Language(s) : C++ ;
--------- I'm having a brainfart and difficulty finding the correct affine transformation to map an arbitrary (but planar) quadrangle into a square space. Something similar is done in UV mapping but, again, having difficulty finding information on this. I'll keep looking but does anybody know how to do this?
Thanks!
On 29/06/2009 at 23:45, xxxxxxxx wrote:
I wrote once a little COFFEE plugin based on an algorithm posted by Per Anders that does exactly the same thing. It turns selected polygons into squares.
> \> MyMenuPlugin::Execute(doc) \> { \> // Called when the menu item is chosen \> var op = GetActiveObject(doc); \> if(!op) return; \> if (!instanceof(op,PolygonObject)) return; \> var sel=op->GetPolygonSelection(); \> if (!sel) return; // no polygon selection, exit now \> \> doc->StartUndo(); \> doc->AddUndo(UNDO_OBJECT,op); \> \> \> var cnt=op->GetPolygonCount(); \> var pnt=op->GetPoints(); \> \> //loop through all the polygons to find the selected ones \> var i=0; \> for (i=0;i<cnt;i++) \> { \> //check if the current polygon is selected \> if (sel->IsSelected(i)) \> { \> //get the polygon points \> var pol=op->GetPolygon(i); \> var p1=pnt[pol->a]; \> var p2=pnt[pol->b]; \> var p3=pnt[pol->c]; \> var p4=pnt[pol->d]; \> \> //calculate the polygon normal, midpoint and size \> var dir=vnorm(vcross(p3-p1,p4-p2)); \> var p5=(p1+p2+p3+p4)/4.0; \> var len=(vlen(p1-p3)+vlen(p2-p4))/4.0; \> \> //set the point positions correctly \> var v1=vnorm(vcross(dir,vnorm(p5-p2))); \> var v2=vnorm(vcross(dir,v1)); \> p1=(len\*v1)+p5; \> p2=(len\*v2)+p5; \> p3=(-len\*v1)+p5; \> p4=(-len\*v2)+p5; \> \> pnt[pol->a]=p1; \> pnt[pol->b]=p2; \> pnt[pol->c]=p3; \> pnt[pol->d]=p4; \> \> op->SetPoints(pnt); \> op->Message(MSG_UPDATE); \> } \> } \> // TODO: Do whatever you want \> doc->EndUndo(); \> op->Message(MSG_UPDATE); \> GeEventAdd(DOCUMENT_CHANGED); \> } \>
On 30/06/2009 at 14:47, xxxxxxxx wrote:
Unfortunately, it must be a transformation matrix since geometry will be inverse transformed (from the square back to the quadrangle). I've found some quad-to-square algorithms but they aren't working for some reason and there is definitely some modification of the matrix homogeneous vector (something that cannot be done with Cinema 4D's matrix as it is always assumed to be (0,0,0,1)!). Typically, a projective transform is applied (when an affine tranformation cannot).
On 30/06/2009 at 20:50, xxxxxxxx wrote:
Found it finally! :D
Here's the full 'test' plugin code just for the curious. This is a 2D transformation only!
//////////////////////////////////////////////////////////////// // TestingPlugin.cpp //////////////////////////////////////////////////////////////// // CommandPlugin class //////////////////////////////////////////////////////////////// // V0.1 2008.05.28 Robert Templeton ////////////////////////////////////////////////////////////////
#include "TestingPlugin.h"
class Matrix2D { public: Real m0; Real m1; Real m3; Real m4; Real m5; Real m7; Real m12; Real m13; Real m15; Matrix2D() { // Unit Matrix m0 = 1.0; m1 = 0.0; m3 = 0.0; m4 = 0.0; m5 = 1.0; m7 = 0.0; m12 = 0.0; m13 = 0.0; m15 = 1.0; } // transform point p by matrix M: q = p*M friend const Vector operator * (const Vector& p, const Matrix2D& M) { Real d = p.x*M.m3 + p.z*M.m7 + M.m15; if (d) d = 1.0f/d; else return Vector(0.0f); Vector q; q.x = ((p.x*M.m0 + p.z*M.m4 + M.m12) * d)-0.5f; q.z = ((p.x*M.m1 + p.z*M.m5 + M.m13) * d)-0.5f; q.y = 0.0f; return q; } };
// Calculate matrix for unit-square to quad mapping // - vertices - square->quad transform //*---------------------------------------------------------------------------* Bool SquareToQuad(Real quad[4][2], Matrix2D* SQ) //*---------------------------------------------------------------------------* { Real x0 = quad[0][0]; Real x1 = quad[1][0]; Real x2 = quad[2][0]; Real x3 = quad[3][0];
Real y0 = quad[0][1]; Real y1 = quad[1][1]; Real y2 = quad[2][1]; Real y3 = quad[3][1];
Real dx3 = x0 - x1 + x2 - x3; Real dy3 = y0 - y1 + y2 - y3;
// afine transform if (!dx3 && !dy3) { SQ->m0 = x1-x0; SQ->m1 = y1-y0; SQ->m3 = 0.0f; SQ->m4 = x2-x1; SQ->m5 = y2-y1; SQ->m7 = 0.0f; SQ->m12 = x0; SQ->m13 = y0; SQ->m15 = 1.0f; } // projective transform else { Real dx1 = x1 - x2; Real dx2 = x3 - x2; Real dy1 = y1 - y2; Real dy2 = y3 - y2;
// determinants Real gtop = dx3 * dy2 - dx2 * dy3; Real htop = dx1 * dy3 - dx3 * dy1; Real bottom = dx1 * dy2 - dx2 * dy1;
if (!bottom) return FALSE; bottom = 1.0 / bottom;
Real g = gtop*bottom; Real h = htop*bottom;
Real a = x1 - x0 + g * x1; Real b = x3 - x0 + h * x3; Real d = y1 - y0 + g * y1; Real e = y3 - y0 + h * y3;
SQ->m0 = a; SQ->m1 = d; SQ->m3 = g; SQ->m4 = b; SQ->m5 = e; SQ->m7 = h; SQ->m12 = x0; SQ->m13 = y0; SQ->m15 = 1.0f; } // Invert //*SQ = !(*SQ); return TRUE; } // Calculate matrix for quad to unit-square mapping // - vertices - square->quad transform //*---------------------------------------------------------------------------* void QuadToSquare(Real quad[4][2], Matrix2D* SQ) //*---------------------------------------------------------------------------* { if (!SquareToQuad(quad, SQ)) return;
// invert through adjoint Real a = SQ->m0, d = SQ->m1, g = SQ->m3; Real b = SQ->m4, e = SQ->m5, h = SQ->m7; Real c = SQ->m12, f = SQ->m13;
Real A = e - f * h; Real B = c * h - b; Real C = b * f - c * e; Real D = f * g - d; Real E = a - c * g; Real F = c * d - a * f; Real G = d * h - e * g; Real H = b * g - a * h; Real I = a * e - b * d;
// Probably unnecessary since 'I' is also scaled by the determinant, // and 'I' scales the homogeneous coordinate, which, in turn, // scales the X,Y coordinates. // Determinant = a * (e - f * h) + b * (f * g - d) + c * (d * h - e * g); Real idet = 1.0f / (a * A + b * D + c * G);
SQ->m0 = A*idet; SQ->m1 = D*idet; SQ->m3 = G*idet; SQ->m4 = B*idet; SQ->m5 = E*idet; SQ->m7 = H*idet; SQ->m12 = C*idet; SQ->m13 = F*idet; SQ->m15 = I*idet; }
// METHODS: TestingPlugin // Execute //*---------------------------------------------------------------------------* Bool TestingPlugin::Execute(BaseDocument* doc) //*---------------------------------------------------------------------------* { PolygonObject* op = PolygonObject::Alloc(4L, 1L); if (!op) return FALSE; doc->InsertObject(op, NULL, NULL, FALSE); CPolygon* pa = op->GetPolygonW(); Vector* va = op->GetPointW(); if (!(pa && va)) return FALSE; pa->a = 0L; pa->b = 2L; pa->c = 3L; pa->d = 1L; /* va[0] = Vector(-25.0f, -96.593f, 6.699f); va[1] = Vector(-25.882f, -96.593f, 0.0f); va[2] = Vector(-48.296f, -86.603f, 12.941f); va[3] = Vector(-50.0f, -86.603f, 0.0f); */ va[0] = Vector(35.355f, -70.711f, -61.237f); va[1] = Vector(50.0f, -70.711f, -50.0f); va[2] = Vector(43.301f, -50.0f, -75.0f); va[3] = Vector(61.237f, -50.0f, -61.237f); op->Message(MSG_UPDATE);
// Test // tv MUST BE IN POLYGON ORDER! Vector tv0 = va[pa->a]; Vector tv1 = va[pa->b]; Vector tv2 = va[pa->c]; Vector tv3 = va[pa->d]; // Center of polygon Vector center = (tv0+tv1+tv2+tv3) * 0.25f; // Move polygon to world 0,0,0 tv0 -= center; tv1 -= center; tv2 -= center; tv3 -= center; // Rotate polygon so that normal made coincident with +Y axis and 0->1 vertices are horizontal on X-Z plane Vector u = !(tv1-tv0); Vector n = !((tv1-tv3)%(tv2-tv0)); Vector v = !(u%n); Matrix m; m.v1 = Vector(u.x, n.x, v.x); m.v2 = Vector(u.y, n.y, v.y); m.v3 = Vector(u.z, n.z, v.z); va[pa->a] = tv0 * m; va[pa->b] = tv1 * m; va[pa->c] = tv2 * m; va[pa->d] = tv3 * m;
// Transform quad to unit square // - Reverse order since C4D uses clockwise and everyone else uses counter-clockwise tv0 = va[pa->a]; tv1 = va[pa->d]; tv2 = va[pa->c]; tv3 = va[pa->b]; Real qi[4][2]; qi[0][0] = tv0.x; qi[0][1] = tv0.z; qi[1][0] = tv1.x; qi[1][1] = tv1.z; qi[2][0] = tv2.x; qi[2][1] = tv2.z; qi[3][0] = tv3.x; qi[3][1] = tv3.z; Matrix2D T; QuadToSquare(qi, &T;); // Yes! va[pa->a] = tv0 * T; va[pa->d] = tv1 * T; va[pa->c] = tv2 * T; va[pa->b] = tv3 * T;
op->Message(MSG_UPDATE); EventAdd(); return TRUE; }
//*---------------------------------------------------------------------------* LONG TestingPlugin::GetState(BaseDocument* doc) //*---------------------------------------------------------------------------* { return CMD_ENABLED; }
// Global Registrant Method for TestPlugin plugin //*---------------------------------------------------------------------------* Bool RegisterTestPluginCommand() //*---------------------------------------------------------------------------* { return RegisterCommandPlugin(ID_TESTPLUGIN, "TestPlugin", 0, NULL, "TestPlugin", gNew TestingPlugin); }
