On 25/06/2009 at 06:04, xxxxxxxx wrote:
Simply take a COFFEE Node and port the code from the SDK to coffee:
> \> \> // angles in Rad-/Euler system \> Matrix HPBToMatrix(const Vector &w;, LONG rot_order) \> { \> Real a,b,c,d,e,f,cosksinn,sinksinn; \> \> SinCos(w.x,d,c); //y = h \> SinCos(w.y,b,a); //x = p \> SinCos(w.z,f,e); //z = b \> \> switch (rot_order) \> { \> case ROT_ZXYGLOBAL: break; //Default \> case ROT_YXZGLOBAL: break; \> { \> sinksinn = d \* b; \> cosksinn = c \* b; \> \> return Matrix(Vector(0.0), \> Vector(c \* e + sinksinn \* f, -c \* f + sinksinn \* e, d \* a), \> Vector(a \* f, a \* e, -b), \> Vector(-d \* e + cosksinn \* f, d \* f + cosksinn \* e, c \* a)); \> } break; \> case ROT_YZXGLOBAL: \> { \> sinksinn = c \* f; \> cosksinn = d \* f; \> \> return Matrix(Vector(0.0), \> Vector(c \* e, -sinksinn \* a + d \* b, sinksinn \* b + d \* a), \> Vector(f, e \* a, -e \* b), \> Vector(-d \* e, cosksinn \* a + c \* b, -cosksinn \* b + c \* a)); \> } break; \> case ROT_ZYXGLOBAL: \> { \> sinksinn = e \* d; \> cosksinn = f \* d; \> \> return Matrix(Vector(0.0), \> Vector(e \* c, -f \* a + sinksinn \* b, f \* b + sinksinn \* a), \> Vector(f \* c, e \* a + cosksinn \* b, -e \* b + cosksinn \* a), \> Vector(-d, c \* b, c \* a)); \> } break; \> case ROT_XZYGLOBAL: \> { \> sinksinn = a \* f; \> cosksinn = b \* f; \> \> return Matrix(Vector(0.0), \> Vector(e \* c, -f, e \* d), \> Vector(sinksinn \* c + b \* d, a \* e, sinksinn \* d - b \* c), \> Vector(cosksinn \* c - a \* d, b \* e, cosksinn \* d + a \* c)); \> } break; \> case ROT_XYZGLOBAL: \> { \> sinksinn = b \* d; \> cosksinn = a \* d; \> \> return Matrix(Vector(0.0), \> Vector(c \* e, -c \* f, d), \> Vector(sinksinn \* e + a \* f, -sinksinn \* f + a \* e, -b \* c), \> Vector(-cosksinn \* e + b \* f, cosksinn \* f + b \* e, a \* c)); \> } break; \> default: break; \> } \> \> //ZXY \> cosksinn = e \* b; \> sinksinn = f \* b; \> \> return Matrix(Vector(0.0), \> Vector(e \* c - sinksinn \* d, -f \* a, e \* d + sinksinn \* c), \> Vector(f \* c + cosksinn \* d, e \* a, f \* d - cosksinn \* c), \> Vector(-a \* d, b, a \* c)); \> } \>
