CallCommand(12144); [Group] doesnt work
    On 09/06/2009 at 14:24, xxxxxxxx wrote:
    Cinema 4D Version:   r11
    Platform:   Windows  ;
    Hi there,
    i have read thru the different threads here concerning joining objects. but dont get it to work.
    what i am doing is loading a document :
    BaseDocument* doc2 = LoadDocument(fileName,0L, NULL);
    and after selecting some objects via
    doc- >SetActiveObject(child, SELECTION_ADD);
    i want to connect them with
    CallCommand(12144);
    i also tried to use SendModelingCommand MCOMMAND_JOIN, but that needs to have a group of subobjects, too, which i dont have in my base scene and CallCommand(100004772); doesnt work, too. the objects remain ungrouped.
    any ideas, hints??
    thanks and cheers,
    Ello
    On 12/06/2009 at 01:31, xxxxxxxx wrote:
    anyone? i still had no success with this. must be something general i guess, but i just have no idea where to look
    cheers,
    ello
    On 12/06/2009 at 15:47, xxxxxxxx wrote:
    I did further tests but still cant get it.
    this should connect all objects in the document (at least from my understanding) but doesnt work:
    > <code>
                                       CallCommand(100004748);
    \>  CallCommand(100004766);
    \>  CallCommand(12144);
    > </code>
    and this should create a group from all objects:
    > <code>
    \>  CallCommand(100004748);
    \>  CallCommand(100004772);
    > </code>
    anyone??
    On 13/06/2009 at 03:06, xxxxxxxx wrote:
    ok, i found out that i first had to ensure that the document was active. now i group all objects, select the parent and CallCommand(12144), but all i get is a polygonobject with no polygons??
    anyone have an idea what could cause this?
    thanks in advance,
    ello
    On 13/06/2009 at 05:09, xxxxxxxx wrote:
    i did it now with SendModelingCommand MCOMMAND_JOIN, but i still like to know why CallCommand(12144) doesnt do it?
    On 15/06/2009 at 08:07, xxxxxxxx wrote:
    Connect only works with polygon objects and editable splines.
    cheers,
    Matthias
