plugin interfere problem??
On 04/06/2009 at 05:15, xxxxxxxx wrote:
Cinema 4D Version:   r11
Platform:   Windows  ;
Hi there,
my betatester found out that if certain plugins are loaded, my shader plugin doesnt show up. what could cause this? i have an unique id from the cafe.
any ideas?
cheers,
ello
On 04/06/2009 at 06:12, xxxxxxxx wrote:
as an additional information, those are:
CHoCoTools Merger,
CHoCoTools Normalo,
CellularShader,
copypastepolys,
DublicateObject,
NoiseDeformer,
PointCollapse,
ShearRotateScale,
Smooth,
SplineConnector,
SplineNoiseDeformer,
ThingsOnSurfaceShader,
UVtoObject
no matter which of them, if one of them is removed, my shader works like it should
so the question is, is there any limitation which is causing this strange behaviour??
On 08/06/2009 at 05:31, xxxxxxxx wrote:
hm, has anyone an idea?
cheers and thanks,
Ello
On 08/06/2009 at 06:27, xxxxxxxx wrote:
I have no idea. The only thing I noticed are that all mentioned plugins except the ChoCoTools are by Michael Welter.
cheers,
Matthias
On 09/06/2009 at 04:09, xxxxxxxx wrote:
Yes, that's correct and the two others are by Marcus Spranger.
Kind regards,
Tom
On 09/06/2009 at 05:04, xxxxxxxx wrote:
You (or he) will have to try your plugin in conjunction with the other plugins (one at a time). Maybe one of the other plugins uses an unregistered ID which is by a funny coincidence the same as yours.
Does the console tell anything useful about your shader failing to register?
Jack
On 09/06/2009 at 11:57, xxxxxxxx wrote:
the console does not give any information. and the funny thing is that it seems to work now :??
On 09/06/2009 at 14:20, xxxxxxxx wrote:
As on old german saying states:
"Reboot tut gut" 🙂
Jack
