Return input object: GetVirtualObjects()
On 03/06/2009 at 15:15, xxxxxxxx wrote:
Cinema 4D Version:   R10-R11
This is my first attempt at an input object generator plugin object so there are some things that are still a bit confusing.
I found out the hard way not to return the original input object (op->GetDown()) in GetVirtualObjects(). Makes sense as it is part of the cloned document sent to GetVirtualObjects() and is released with that document afterwards I would imagine.
I am using GetAndCheckHierarchyClone() to get a polygonized clone representation but this is further modified. But the original (unmodified) input object still needs to be returned also. Should I just make an additional clone to be returned in my Null object parent?
On 03/06/2009 at 17:16, xxxxxxxx wrote:
Also, I take it that if dirty=TRUE then 'res' from GetAndCheckHierarchyClone() represents the currently built cache, modifications and all, whereas if dirty=FALSE then 'res' represents the polygonized input object (hierarchy)???
Thanks!
On 04/06/2009 at 07:28, xxxxxxxx wrote:
On the first post, I found an old Mikael Sterner post which suggests that GetClone() should be used for additional copies to be modified (YAY!).
No idea about the second but we'll see. 🙂
On 07/06/2009 at 02:39, xxxxxxxx wrote:
Hi.
I do it like this:
if it's dirty, then I build my virtual object hierarchy and return it.
if its not dirty then I return the 'res' from
GetAndCheckHierarchyClone(), which i think just means that nothing has changed, and cinema can use the cached virtual hierarchy.
greetings,
Daniel
On 07/06/2009 at 09:18, xxxxxxxx wrote:
That should have been in my second post:
dirty=FALSE, res=built cache
dirty=TRUE, res=polygonized input
And that, as you note, seems to be the case.
