On 22/05/2009 at 12:42, xxxxxxxx wrote:
User Information: Cinema 4D Version: r11 Platform: Language(s) : C++ ;
--------- Hi , i am using this code to get a user spline from an input field and create a clone to be able to for example read out points with "vPosition = splineObj->GetSplinePoint(ccpos, 0, NULL);"
if(userSpline) { splineObj = ((BaseObject* )(userSpline->GetClone(COPY_NO_BITS, NULL)))->GetRealSpline(); } everything works well, except that once again i have a memory leak. i think i have to free something, but what?? it isnt the splineObj, but i guess its something that happens when using GetRealSpline().. which i need to use, since the use should be able to use parametric splines... thanks for any hints, cheers, ello
On 22/05/2009 at 13:28, xxxxxxxx wrote:
The memory leak is your clone, I guess. You should store the pointer to the clone in a separate Variable, get the real spline from it and then free the clone after use.
Cheers, Jack
On 22/05/2009 at 13:52, xxxxxxxx wrote:
thank you.. got it working
