On 19/05/2009 at 04:30, xxxxxxxx wrote:
Cinema 4D Version: 11
Platform: Windows ; Mac OSX ;
Language(s) : C.O.F.F.E.E ;
Need to check.
In a coffee expression plugin tag or a regular COFFEE tag I have a Userdata.
Thing is, if I try to set it to a value (like current frame as in the
included code) it doesn't update the Userdata if "inside" a BaseContainer
call and the basecontainer is a constant variable.
I can print the Userdata from "within" the bc and it's correct,
but not actually set the correct value of the Userdata.
Setting the Userdata before or after the bc is ok.
Should this be considered normal? To me it looks inconsistent
(Since it prints)
Lennart
> \> const var MYMEMORY_ID = 1000001; \> \> main(doc,op) \> { \> var frame = doc->GetTime()->GetFrame(doc->GetFps()); \> var pos = op->GetMg()->GetV0(); \> \> ////// before container \> var bc = op->GetContainer(); \> \> op#ID_USERDATA:1 = frame; // not work "inside" bc \> println(op#ID_USERDATA:1); // works "inside" bc \> \> var memopos = bc->GetData(MYMEMORY_ID); \> if(!memopos) memopos = pos; \> bc->SetData(MYMEMORY_ID,pos); \> op->SetContainer(bc); \> ///// after container \> } \>
