execute Center Axis with parameters
On 18/05/2009 at 03:22, xxxxxxxx wrote:
Cinema 4D Version:   R11
Platform:
Hi all out there ;-}
I want to center the Axis of all objekts to there center ;-}.
But with CallCommand(1010819); only  the Dialogbox ist opening.
Is ther a way to set the parameters:
with children
all objects
enable auto Update
and at last run the modification?
Thanks to your help.
Chears Ronny
On 25/05/2009 at 02:51, xxxxxxxx wrote:
Unfortunatly the Axis Center command can't be executed through SendModelingCommand(). I am afraid you have to write your own axis center function.
cheers,
Matthias
On 03/06/2009 at 07:35, xxxxxxxx wrote:
> cheers,
> Matthias
...which is a pain in the ass, because you can't "just" set the new axis (the routine needed to do that with is internal/private)... if you SetMl() on the object, the vertices get moved according to the new matrix, so you have to modify the vertices by the (inverse) delta of the old/new matrix as well.
