DependenceList Issue
On 15/05/2009 at 16:34, xxxxxxxx wrote:
Cinema 4D Version:   r11
Platform:   Windows  ;
hello,
i am using op->AddDependence(hh, child); and op->TouchDependenceList(); to hide the child objects of my object plugin. works fine as long as i dont use my object plugin as a child of another of my object plugins
e.g.
-plugin
--cube
works, the cube is invisible
plugin
-plugin
--cube
the cube is visible
i guess that it is a common mistake of mine which is causing this, any ideas?
thanks and cheers,
ello
On 18/05/2009 at 12:52, xxxxxxxx wrote:
hm, anyone? i still didnt manage to solve this problem
thanks,
ello
On 18/05/2009 at 13:30, xxxxxxxx wrote:
this is how i can hide the childs child;
\>       if (child)
\>            main->AddDependence(hh, child);
\>            main->TouchDependenceList();
\>            if (child->GetDown())
\>                 main->AddDependence(hh, child->GetDown());
but if i cannot endlessly go deeper tis way. there must be another solution
On 19/05/2009 at 03:46, xxxxxxxx wrote:
Look into the SDK and search for GetAndCheckHierarchyClone()
Greetings,
Jack
On 21/05/2009 at 15:19, xxxxxxxx wrote:
ok, after checking the GetAndCheckHierarchyClone... i got the dependencies working for nested pluginobjects properly but always the child of the nested object isnt hided anymore. what do i need to do that none of those child objects is visible (without using SetEditorMode/SetRenderMode )??
thanks for your patience 🙂
cheers,
ello
code at the beginning regarding the dirty thing:
\>       //walk thru childs and set dependence
\>       BaseObject* tp = NULL;
\>       Bool dirty=FALSE;
\>       dirty = op->CheckCache(hh) || op->IsDirty(DIRTY_DATA|DIRTY_CHILDREN);
\>       if (!dirty)
\>            op->NewDependenceList();
\>            for (tp=child;tp;tp=tp->GetNext())
\>                 op->AddDependence(hh,tp);
\>       dirty = dirty || !op->CompareDependenceList();
\>       if (!dirty)
\>            blDelete(main);
\>            op->TouchDependenceList();
\>            return op->GetCache(hh);
at the end of the generator (right before the return main;) i have this code:
\>       child = op->GetDown();
\>       return main;
On 22/05/2009 at 00:10, xxxxxxxx wrote:
Hm, don't know because I do it totally different in my plugin. I never used TouchDependencyList 😉 Maybe you'll have to iterate the hierarchy and touch all children yourself.
On 22/05/2009 at 02:22, xxxxxxxx wrote:
GetAndCheckHierarchyClone() does use it, so i thought its a good idea.. i'll do some more tests what happens when i remove it, but u thought it belongs there to hide the childs
i'll try the iterating again, maybe i did something wrong last night
thanks for your input
On 22/05/2009 at 09:28, xxxxxxxx wrote:
well, CompareDependenceList needs to be there, otherweise even the first child isnt hidden.
iterating the hierarchy doesnt help, or is this the wrong was to do so?
\>                 BaseObject *tp2 = tp->GetDown();
\>                 if (tp2)
\>                      for (tp2=tp;tp2;tp2=tp2->GetNext())
\>                           op->AddDependence(hh,tp2);
dowsnt work if i Touch them by myself, too:
\>            if (tp2)
\>                      tp2->Touch();
any help here appreciated.. as its a bit frustrating 🙂
cheers,
ello
On 26/05/2009 at 02:47, xxxxxxxx wrote:
It looks like your are not going through all of the children objects. Here is some simple working sample code:
> \> void StepThru(BaseObject \*op, BaseObject \*child, HierarchyHelp \*hh, LONG &childcnt;) \> { \>      while (child && !child->GetBit(BIT_CONTROLOBJECT)) \>      { \>           op->AddDependence(hh, child); \> \>           StepThru(op, child->GetDown(), hh, childcnt); \> \>           child = child->GetNext(); \> \>           childcnt++; \>      } \> } \> \> // create morphed object \> BaseObject \*MorphMixerObject::GetVirtualObjects(PluginObject \*op, HierarchyHelp \*hh) \> { \>      BaseObject \*pp = NULL, \*child = NULL; \>      child = op->GetDown(); \>      if (!child) return NULL; \> \>      // start new list \>      op->NewDependenceList(); \> \>      // check cache for validity and check master object for changes \>      Bool dirty = op->CheckCache(hh) || op->IsDirty(DIRTY_DATA); \> \>      LONG childcnt = 0; \> \>      //step thru all children \>      StepThru(op, child, hh, childcnt); \> \>      // if child list has been modified somehow \>      if (!dirty) dirty = !op->CompareDependenceList(); \> \>      // mark child objects as processed \>      op->TouchDependenceList(); \> \>      // if no change has been detected, return original cache \>      if (!dirty) return op->GetCache(hh); \> \>      GePrint(LongToString(childcnt)); \> \>      return BaseObject::Alloc(Onull); //return your generated object \> } \>
cheers,
Matthias
On 26/05/2009 at 04:10, xxxxxxxx wrote:
Yes, some good old recursing action! To understand recursions, you first have to understand recursions. But once that's done, they're fun 🙂
Jack
On 26/05/2009 at 12:33, xxxxxxxx wrote:
wow, thank you so much Matthias, after some changes it works so cool! and it helps to understand the principle much better because it is so clean.
cheers,
Ello
