On 14/05/2009 at 09:43, xxxxxxxx wrote:
User Information: Cinema 4D Version: 11.027 Platform: Windows ; Language(s) : C.O.F.F.E.E ; C++ ; XPRESSO ;
--------- I'm having a priority issue that I believe is related to a spline generator. I'm using xpresso to get the location of polygons on a deformed mesh. To enable this I have to have the xpresso tag at the generator priority level, and this works fine. The problem is when I try to move the points of a spline to that new position. The points are always lagging a frame behind.
I believe this problem is caused because the spline is generated before the points are moved. Is there a way to force the spline to regenerate at a later priority level.
I tried writing a tag plugin that on Execute just said > op->SetDirty(DIRTY_DATA);
but that didn't help any. I'd welcome any suggestions.
- Carter
On 18/05/2009 at 05:09, xxxxxxxx wrote:
I've provided an example in hopes of getting some feedback. I wouldn't normally care that much but this is for a project that really relies on this. It involves straps attached to the character's body.
http://studentpages.scad.edu/~ccross20/splineExample.c4d
On 18/05/2009 at 05:25, xxxxxxxx wrote:
Interestingly I just noticed that if you have the spline in point edit mode it works just fine.
On 25/05/2009 at 03:24, xxxxxxxx wrote:
This looks like a bug. I have reported it.
