On 01/05/2009 at 15:46, xxxxxxxx wrote:
User Information: Cinema 4D Version: 11.021 Platform: Windows ; Language(s) : C.O.F.F.E.E ;
--------- Create a new script.
The code in the Menu State should by default be:
> ENABLE=TRUE;
ENABLE=TRUE;
Drag the script somewhere into your interface.
Now add this line:
> ENABLE=TRUE; \> CHECK = TRUE;
The icon is not in a positive checked state. Now, add a space between ENABLE the = and TRUE; so that your code is:
> ENABLE = TRUE; \> CHECK = TRUE;
Your icon will now be in a checked state. I don't know why, but if the spaces aren't there after ENABLE it won't execute the CHECK block.
