error C2065: 'layerObject': nichtdeklarie
On 29/04/2009 at 07:39, xxxxxxxx wrote:
Cinema 4D Version: 11
Platform: Windows ;
Hi all,
I'm trying to read out the Layer informations.
Searching the forum I found an example :Just use GetlayerData() with the layer and check the states of the structure elements of the layerData structure. Here a little example that prints all states of all layers in a scene.
You can of course also get the layerData directly from objects, tags etc.static void StepThrulayers(GeListNode *layer, BaseDocument *doc)
while (layer)
layerObject *lobj = (layerObject* )layer;
const layerData *ldata = lobj->GetlayerData(doc, FALSE);
GePrint(lobj->GetName());
if(ldata->solo)
GePrint("Solo On");
else
GePrint("Solo Off");
if(ldata->view)
GePrint("View On");
else
GePrint("View Off");
if(ldata->render)
GePrint("Render On");
else
GePrint("Render Off");
if(ldata->manager)
GePrint("Manager On");
else
GePrint("Manager Off");
if(ldata->locked)
GePrint("Locked On");
else
GePrint("Locked Off");
if(ldata->animation)
GePrint("Animation On");
else
GePrint("Animation Off");
if(ldata->generators)
GePrint("Generators On");
else
GePrint("Generators Off");
if(ldata->deformers)
GePrint("Deformers On");
else
GePrint("Deformers Off");
if(ldata->expressions)
GePrint("Expressions On");
else
GePrint("Expressions Off");
StepThrulayers(layer->GetDown(), doc);
layer = layer->GetNext();
Bool MenuTest::Execute(BaseDocument *doc)
GeListHead *llist = doc->GetlayerObjectRoot();
if(!llist)
GePrint("no list");
return FALSE;
StepThrulayers(llist->GetFirst(), doc);
return TRUE;
But when I try to compile it I allways get the error:
1>c:\maxon\cinema 4d r11 development\plugins\plugin-container-layer lesen\source ool\v4d_1.cpp(20) : error C2065: 'layerObject': nichtdeklarierter BezeichnerHere is my complete Code:
#include "c4d.h"
#include "c4d_symbols.h"
#include "OperatingSystem.h"
#include "ge_vector.h"
class HelloWorld : public CommandData
public:
virtual Bool Execute(BaseDocument* doc);
while (layer)
if(ldata->solo)
GePrint("Solo On");
else
if(ldata->view)
GePrint("View On");
else
if(ldata->render)
else
if(ldata->manager)
else
if(ldata->locked)
else
else
else
else
else
Bool HelloWorld::Execute (BaseDocument* doc) //This function is called by Cinema4D when the plugin shall be executed.
BaseObject *op=NULL;
op=doc->GetFirstObject();
if (!op) return false; // Verlässt die Funktion
ModelingCommandData cd;
cd.doc = doc;
cd.op = op;
GePrint("Hello World!");
if(!llist)
GePrint("no list");
return FALSE;
return true;
Bool RegisterV4D_1(void)
HelloWorld *helloWorld = NULL;
// initialize global resource object
if (!resource.Init()) return FALSE;
// create new instance of HelloWorld class
helloWorld = gNew HelloWorld;
return (RegisterCommandPlugin(PLUGIN_ID, GeLoadString (IDS_PLUGIN_NAME),0,"Icon.tif", GeLoadString (IDS_PLUGIN_DESCR), helloWorld));
Does anybody here know how to solve the Problem.
Thanks a lot.
On 29/04/2009 at 08:59, xxxxxxxx wrote:
It looks like a typo/syntax error. It's LayerObject and LayerData not layerObject and layerData.
cheers,
Matthias
On 30/04/2009 at 01:24, xxxxxxxx wrote:
Hi Matthias,
thanks so much!!!
Great job.
Could it be that the VS2008 is a little bit kiki here.
We compiled it in a VS2005 2 weeks ago and everything was fine.
Now in VS2008 we got the errrors.
On 30/04/2009 at 03:30, xxxxxxxx wrote:
No, C++ is just a case sensitve language.
cheers,
Matthias
