On 24/04/2009 at 07:50, xxxxxxxx wrote:
User Information: Cinema 4D Version: 10.1 Platform: Windows ; Mac OSX ; Language(s) : C++ ;
--------- Hi,
in my Generator object, I use textures/shaders for creating geometry. Since I use caching to speed up the performance, I do the following to check if anything in the object has changed, so the cache has to be recalculated:
> \> Bool dirty = op->CheckCache(hh) || op->IsDirty(DIRTY_DATA); \> if (!dirty) return op->GetCache(hh); \>
Is it possible to trace changes in a shader/texture (class PluginShader)? Of course, when the shader changes, my object must also be recalculated.
Since, there is no PluginShader::CheckCache(), maybe this is possible using messages, but I don't know.
Any tipps? Thanks in advance!
Cheers, Jack
On 24/04/2009 at 08:27, xxxxxxxx wrote:
(Of course, in the thread title it should write "Trace Changes", not "Trance Changes")
On 27/04/2009 at 01:10, xxxxxxxx wrote:
You can only check for container changes, IsDirty(DITY_DATA).
On 27/04/2009 at 03:25, xxxxxxxx wrote:
Ah! Nice, sometimes it's so simple Thank, I will try that!
