On 07/04/2009 at 07:27, xxxxxxxx wrote:
User Information: Cinema 4D Version: Platform: Language(s) : C++ ;
--------- Hi,
I would like to get the current active tool but can't find any method. Well, I found the settings container but I would like to get the tool as BaseList2D element.
Any suggestions?
Thanks and bye. Shawni
On 07/04/2009 at 07:31, xxxxxxxx wrote:
BaseDocument::GetAction()
On 07/04/2009 at 08:28, xxxxxxxx wrote:
thanks, works fine, but the stuff I want to do, does not work.
I just want to call a button. Via BaseDocument::GetAction() and FindPlugin(..., 0) I get the plugin instance.
object = FindPlugin(...)
DescriptionCommand dc; dc.id = DescID(id); Py_RETURN_BOOL(object->Message(MSG_DESCRIPTION_COMMAND,&dc;));
It returns True, but the button was not really pressed. Any suggestion what might be wrong?
Thanks.
On 07/04/2009 at 08:57, xxxxxxxx wrote:
To set the current tool, use BaseDocument::SetAction(). That enables the tool by its ID (should work with plugin tools as well - best to test). You can't 'do' anything with the tool though. Tools aren't commands, they are tools and require user interaction thereafter.
Not sure what you are after.
On 07/04/2009 at 09:15, xxxxxxxx wrote:
I just want to call a button (see CloneTool ->"Apply" or ClothTag->"Calculate"). I know that a tool is not just a button, but a tool might contain a button.
The new Coffee SDK contains CallButton(...) which does exactly what I want to do, just in C++
On 07/04/2009 at 09:42, xxxxxxxx wrote:
You might need to do it this way:
object = FindPlugin(...); DescriptionCommand descCMD; descCMD.id = DescID(DescLevel(id,DTYPE_BUTTON,0)); Py_RETURN_BOOL(object->Message(MSG_DESCRIPTION_COMMAND, &descCMD;));
I'm just not sure if all of the possibilities in the FindPlugin() part will result in valid 'plugin' ids that result in a BasePlugin* being returned.
On 08/04/2009 at 03:44, xxxxxxxx wrote:
hi, doesn't work either. Hmm..
On 08/04/2009 at 04:24, xxxxxxxx wrote:
This seems to work. I used the CreatePolygon tool to test.
> \> Bool MenuTest::Execute(BaseDocument \*doc) \> { \> LONG tool_id = doc->GetAction(); \> \> BasePlugin \*tool = NULL; \> tool = FindPlugin(tool_id, C4DPL_TOOL); \> \> if(!tool) return FALSE; \> \> DescriptionCommand dc; \> dc.id = DescID(MDATA_CREATEPOLYGON_BUTTON); \> tool->Message(MSG_DESCRIPTION_COMMAND, &dc;); \> \> EventAdd(); \> \> return TRUE; \> } \>
On 08/04/2009 at 06:40, xxxxxxxx wrote:
This works fine here, too. In my case its the Apply Button of the Clone Tool. But I will check that again and I will tell you what I did wrong.
cheers, Shawni
On 13/04/2009 at 08:49, xxxxxxxx wrote:
Hi, I guess I've the correct IDs.
> \> CallCommand(450000042); \> LONG tool_id = doc->GetAction(); // select the Clone tool \> \> BasePlugin \*tool = NULL; \> tool = FindPlugin(tool_id, C4DPL_TOOL); \> \> if(!tool) return FALSE; \> \> DescriptionCommand dc; \> dc.id = DescID(MDATA_APPLY); \> tool->Message(MSG_DESCRIPTION_COMMAND, &dc;); \> \> EventAdd(); \>
Any suggestions? Thanks.
On 14/04/2009 at 03:00, xxxxxxxx wrote:
It seems that the DescriptionToolData Apply, New Transform and Reset Values buttons are triggered differently. I have asked the developers how the CallButton() command is working internally.
On 20/04/2009 at 04:08, xxxxxxxx wrote:
heyho, any news?
On 21/04/2009 at 01:05, xxxxxxxx wrote:
Quote: Originally posted by Shawni on 20 April 2009 > > * * * > > heyho, any news? > > > * * *
Sorry, not yet.
On 28/04/2009 at 01:20, xxxxxxxx wrote:
Hope it's not too late, anyways here is the working code.
> \> Bool MenuTest::Execute(BaseDocument \*doc) \> { \> LONG tool_id = doc->GetAction(); \> \> BasePlugin \*tool = NULL; \> tool = FindPlugin(tool_id, C4DPL_TOOL); \> if (!tool) return FALSE; \> \> BaseContainer msg(BFM_ACTION); \> msg.SetLong(BFM_ACTION_ID, 1440); \> msg.SetLong(BFM_ACTION_VALUE, TRUE); \> \> DescriptionCommand dc; \> dc.id = DescID(DescLevel(MDATA_APPLY, DTYPE_BUTTON, tool->GetType())); \> \> DescriptionCheckUpdate du; \> du.doc = doc; \> du.descid = &dc.id; \> du.drawflags = 0; \> \> tool->Message(MSG_DESCRIPTION_COMMAND, (void\* )&dc;); \> tool->Message(MSG_DESCRIPTION_CHECKUPDATE, (void\* )&du;); \> tool->Message(MSG_DESCRIPTION_USERINTERACTION_END); \> tool->Message(MSG_TOOL_RESTART); \> \> EventAdd(); \> \> return TRUE; \> } \>
As you can see you have too send some more messages to make it work. This should work with every button. It's almost identically with internal code for CallButton().
On 28/04/2009 at 02:10, xxxxxxxx wrote:
hey Matthias, wow, thank you! Works fine.
