_api Project File Unloaded
On 18/03/2009 at 05:32, xxxxxxxx wrote:
Cinema 4D Version: 11
Platform: Windows ;
I'm trying to resume work on a plugin in Visual C++ 2008 Express Edition after a 2 month hiatus.The Visual Studio Conversion Wizard appears, saying that the project being opened was created in a previous version and must be converted.
After conversion, the Solution Explorer says that the _api project file was unloaded. Reload Project is unsuccessful.
I haven't changed anything since last working on the plugin, when all was well.
Can anyone provide a solution to this problem?
On 19/03/2009 at 04:52, xxxxxxxx wrote:
I have no idea, sorry. Currently VS2008 is not officially supported by MAXON, meaning you have to use it on your own risk.
cheers,
Matthias
On 19/03/2009 at 05:15, xxxxxxxx wrote:
Okay, thanks for the reply.
I might have to give VS 2005 a try.
On 19/03/2009 at 05:51, xxxxxxxx wrote:
Why not simply adding the api project back on yourself? ;-) Then simply set the dependancies again. Should be it (drag and drop the project file of the api into the project window of VS).
> Quote: _Can anyone provide a solution to this problem?
_
On 19/03/2009 at 06:03, xxxxxxxx wrote:
Okay, it's working!
The problem was that somehow _api.vcproj had become write-protected, which was preventing it from being converted.
> Quote: Originally posted by 3D Designer on 19 March 2009
> * * *Thanks for the suggestion, this helped put me on the right track.
