set parameter of a description (*.res)
On 17/03/2009 at 10:43, xxxxxxxx wrote:
Cinema 4D Version:   11
Platform:   Windows  ;
how do I change dynamicly a parameter in a Container of a res-file?
I start with these res-file:
> \> CONTAINER Tmytagplugin \> { \>     NAME Tmytagplugin; \>     INCLUDE Texpression; \> \>     GROUP ID_TAGPROPERTIES \>     { \>           LINK PARENT { } \>           BOOL UP_VEC { } \>           LINK UP_VECTOR { HIDDEN;} \>     } \> } \>
I want to show the 3. Option "UP_VECTOR" in the Attribute-Manager, if the boolean UP_VEC is enabled.
The problem is, I don't know how to access the description in the right way:
I have only access to
> MyTagPlugin::Init(GeListNode \*node)
and
> MyTagPlugin::Execute(PluginTag \*tag, BaseDocument \*doc, BaseObject \*op, BaseThread \*bt, LONG priority, LONG flags)
but how can I access my description?
furthermore I don't know how to use:
Bool SetParameter(const DescID & id, const BaseContainer& param, const DescID& groupid);
DescID id => DESC_HIDE
DescID groupid => UP_VECTOR
but how should i create the BaseContainer param ??
I would prefer some examples...
Grumpf 🙂
On 17/03/2009 at 10:47, xxxxxxxx wrote:
You have to overload GetDDescription() for dynamic descriptions. Check the MorphMixer and the LookAtCamera SDK examples for the use of it.
cheers,
Matthias
On 17/03/2009 at 13:51, xxxxxxxx wrote:
Thanks, for the fast reply 🙂
Now it works!
The stuff with the DescIDs (DescLevel) was a bit difficult..
but the LookAtCamera-Example was very helpful!
greetz 🙂
