On 13/03/2009 at 18:52, xxxxxxxx wrote:
User Information: Cinema 4D Version: 10.5 Platform: Windows ; Language(s) : C.O.F.F.E.E ;
--------- Hi wise guys,
after searching hours for this problem, I couldn't find any solution. Maybe you can help. I tried to create a OCube-Object, make it editable and then subdivide it. First two points work fine, but I can't subdivide it with a further SendModelingCommand() in the same routine. The odd thing on this is, that there is no error message, everything seems to work fine.
> \> RockGenPlugin::Execute(doc) \> { \> var RockObject = AllocObject(Ocube); \> var RockPhongTag = AllocTag(TPhong); \> var bc = new(BaseContainer); \> \> RockObject->SetName("RockGenObject"); \> doc->InsertObject(RockObject,NULL,NULL); \> RockObject->InsertTag(RockPhongTag,NULL); \> \> RockPhongTag#PHONGTAG_PHONG_ANGLELIMIT = TRUE; \> RockPhongTag#PHONGTAG_PHONG_ANGLE = PI\*80/180; \> RockPhongTag#PHONGTAG_PHONG_USEEDGES = TRUE; \> \> SendModelingCommand(MCOMMAND_MAKEEDITABLE, doc, RockObject, bc, MODIFY_ALL); // works fine. \> \> bc->SetData(MDATA_SUBDIVIDE_HYPER, TRUE); \> bc->SetData(MDATA_SUBDIVIDE_ANGLE, PI); \> bc->SetData(MDATA_SUBDIVIDE_SUB, 1); \> \> SendModelingCommand(MCOMMAND_SUBDIVIDE, doc, RockObject, bc, MODIFY_ALL); // doesn't work, but raises no error. \> \> DrawViews(DA_FORCEFULLREDRAW); \> var d = new(RockGenDialog); \> d->Open(-1,-1); \> return TRUE; \> } \> \>
In another routine (e.g. a dialog::command routine) it works...
And there is another question: Why isn't it possible to run multiple Modeling commands in a queue? Maybe like this:
> \> SendModelingCommand(MCOMMAND_MAKEEDITABLE|MCOMMAND_SUBDIVIDE|MCOMMAND_MELT, doc, op, bc, MODIFY_ALL); \>
Would be a nice feature...
Oh, and please don't bully me for that dirty code, errorcatchers and so on will definitely be added.
greeting, Robert
On 14/03/2009 at 12:22, xxxxxxxx wrote:
never mind, got it...
I just forgot to assign the object to a new variable like this:
> var dummy = doc->FindObject("RockGenObject");
But is this the optimal way?
regards, Robert
On 14/03/2009 at 15:42, xxxxxxxx wrote:
have you seen this part in the sdk doc
"If a document is provided, an undo is automatically added. If doc is NULL, no undo is added, so one can collect multiple SendModelingCommand() calls "
On 14/03/2009 at 17:46, xxxxxxxx wrote:
Darn, that worked too... Thanks for that...
