On 10/03/2009 at 11:42, xxxxxxxx wrote:
User Information: Cinema 4D Version: 10.1 Platform: Windows ; Language(s) : C.O.F.F.E.E ;
--------- i have a script that loads a texture into a material channel. i can get texture to load if the texture is in the same folder as project with filename as eg.. "texture.jpg". but if i try to load it from a different folder eg... "c:\Folder\subfolder exture.jpg" it loads the path as "c:Foldersubfoldertexture.jpg"
does anyone know how to get the brackets to stay in the path?
On 10/03/2009 at 20:18, xxxxxxxx wrote:
i dont know if this will make people understand more but i said the wrong name. its meant to be "back slash" \ (not bracket)
On 10/03/2009 at 20:56, xxxxxxxx wrote:
never mind. i got it working. i had to add double back slash eg... change c:\folder\image.jpg to c:\\folder\\image.jpg (just incase someone has same problem)
On 11/03/2009 at 14:16, xxxxxxxx wrote:
It is generally better to use AddLast(folder or file name) to construct the path instead of writing it directly. This also makes sure it is plattform independently generated I´d say.
On 11/03/2009 at 15:07, xxxxxxxx wrote:
that wont work? because im using it to load a texture to a material (same material all the time)then apply it to an object.
wouldnt "AddLast(folder or file name)" just use the last path a browsed to. which i dont wont because i could change the path, which would make the code not work anymore
On 11/03/2009 at 16:15, xxxxxxxx wrote:
What I mean is something like this:
Filename fn = "C:"; fn->AddLast("folder"); fn->AddLast("image.jpg");
You shouldn´t explicitly define the path as you did. It doesn´t matter how you use it, I am talking about the compatibility of the path construction if you know what I mean.
