On 03/03/2009 at 02:13, xxxxxxxx wrote:
User Information: Cinema 4D Version: 11 Platform: Mac ; Language(s) : C++ ;
--------- Hi
I am sorry, but whyever, my head don't want to understand how to work with this stuff seriously.
I rewrite the part where to get/set values of BaseList2D objects. For example: To get a segments count of a sphere you can just call
Sphere[1111] => Returns "24" on standard
To return the first userdata element you can call Sphere[USERDATA_ID, 1]
That looks nice and is easy to understand, but I have a problem to understand how to get a level down in an element ( depends on the element type, yes).
For example, to get the x element of a vector I guess I have to check a new Level. How would you access this. Please note, you don't know the type of it.
I thought I could do this Cube[1100, 1000] = > 1100 is the vector of the cube size and 1000 is the X element of it. Yes, I could just call Cube[1000] to return the whole vector but maybe just return the X component would be cool too.
How would you access this type in C++?
Thanks
On 03/03/2009 at 02:26, xxxxxxxx wrote:
How do you set/get your parameter, with Get/SetParameter()? If so why don't you use GeData::GetType() to retrieve the type?
This is an example how to access a subchannel of the vector type:
> \> DescID(DescLevel(ID_BASEOBJECT_POSITION,DTYPE_VECTOR,0),DescLevel(VECTOR_X,DTYPE_REAL,0)) \>
On 03/03/2009 at 02:42, xxxxxxxx wrote:
Yes, I can use GeData::GetType() when I already got the element, but I don't mean the type of GeData. In your code you use the types: DTYPE_REAL and DTYPE_VECTOR
That means the user has to call this:
> \> Cube[ (ID_BASEOBJECT_POSITION,DTYPE_VECTOR, 0) (VECTOR_X,DTYPE_REAL,0) ] \>
This is just the python way. I would pass these ids to the DescID. In this case I have to pass the type. Could it be possible just to pass:
> \> ID_BASEOBJECT_POSITION and VECTOR_X without the types? \>
For example:
> \> Cube[ (ID_BASEOBJECT_POSITION) (VECTOR_X) ] \>
which would be much cooler.
Bye.
On 03/03/2009 at 03:06, xxxxxxxx wrote:
Ah, ok, now I got it. I have to do a bit research on my own. I guess it must be possible somehow as COFFEE is doing basically the same.
On 04/03/2009 at 03:16, xxxxxxxx wrote:
It seems that you have to get first the typ of each description level.
For instance to change a cube's X length you would do something like this in Python I guess:
> \> Cube[ (PRIM_CUBE_LEN) (VECTOR_X) ] \>
In C++ you have to do something like this:
- get the type of the first level
> \> cube->GetParameter((DescLevel(PRIM_CUBE_LEN), d, 0) \>
- get the type of the second level
> \> cube->GetParameter(DescID(DescLevel(PRIM_CUBE_LEN,DTYPE_VECTOR,0),DescLevel(VECTOR_X)), d, 0) \>
- now you all the necessary types to do something with the parameters
I still have to wait for a final answer of the developers but I think this is how it's done.
On 04/03/2009 at 05:44, xxxxxxxx wrote:
yeap, i guess thats it. works fine thx...
