Control Nodes with COFFEE
On 24/02/2009 at 03:41, xxxxxxxx wrote:
Cinema 4D Version: R10
Platform: Windows ;
Language(s) : C.O.F.F.E.E ; C++ ; XPRESSO ;---------
Hi,im trying to generate and control several XPRESSO Nodes with a COFFEE Script. Currently I pass the Node Parameters to an Objects UserData to gain access.
But, is it possible to get direct access to Node Parameters with COFFEE and how can I add new Nodes to an existing XPRESSO Tag (with a COFFEE Script).
Thanks in advance
On 24/02/2009 at 04:48, xxxxxxxx wrote:
Unfortunatly this is not possible with COFFEE.
cheers,
Matthias
On 24/02/2009 at 04:59, xxxxxxxx wrote:
just a suggestion:
Otherwise you can take a look at this page:
http://py4d.xpresso24.com/doc/modules/GvNode.html#c4d.GvNodeThat should help you. This plugin is very similiar to Coffee and works fine. Py4d does exactly what you are trying to do.
Matthias, just delete this message if this is a little bit to much of "ad" :)
Bye,
sebastian
